Results 1 to 3 of 3
Thread: Noise on AM/FM radio - source?
    Dandenong Ranges - Victoria
    Before I go randomly looking for loose wires and corroded grounding points has anyone had a Freebie radio go feral with substansial engine speed noise on AM in particular but also noticable on FM and faintly on CD?
    If so give me some pointers before I break something difficult to put back together
    my moneys on a diode in the rectifier bridge in the alternator letting go.
    Adelaide Hills, SA
    If the diode/alternator angle doesn't work, check for loose components near the alternator or ignition system - maybe a suppressor or filter has lost its earth connection. Don't know Freebies very well - do they have an electric fuel pump? If they do, check for bad earth or loose components near there too.
    If you don't see anything there, it may be that a filter has lost its earth near the radio itself.
    A handheld AM radio might help you locate the source (or it might just confuse things since sometimes the noise seems to come from everywhere - once it is on the power wiring it probably couples through the whole car).
    Good luck with it - I will be offline for a week or so, I'll read all about your triumphant success later...
    Paul.
    Paul
    1971 IIA ute, 186 (Betsy)
    they're not dents, they're character...
