According to the owner's manual - No.
Hi guys, anyone know if the Puma likes Bio, i know the Tdi likes it and the Td5 doesn't cause of the rubber shock cones in the injectors but i havn't heard anything about the Puma?
as far as i'm aware NO new engine likes BIO......the seals and stuff they use cant take it
well that's thinking ahead then isn't
Now where's that enviro-greeny friendly LR video i saw posted again
EVL '96 Defender 110 - Emerald '63 2a Ambulance 112-221 - Christine '93 Rangy - Van '98 Rangy - Rachael '76 S3 GS - Special '70 S2a GS - Miss B '86 Rangy - RAAF Tactical 200184 & 200168
1995 Defender 110 300TDI :D
1954 86" Series 1 Automatic :eek:
Ex '66 109" flat deck, '82 109" 3 door, '89 110 CSW V8, '74 Range Rover, '66 88" soft top, '78 88" soft top, '95 Disco ES V8, '88 Surf, '90 Surf, '84 V8 Surf, '91 Vitara.
Any ideas on a blend maybe, say 50% bio.
Recycling fish and chip oil is pretty green isn't it?Ah but it is much more forward thinking by Landrover than the greenies, crops should be used for feeding people not cars.....................
The english have finally worked this out and are cutting back on biofuel production
Mahn England
Ex 300Tdi Disco:
i wouldn't even attemp it
a guy brought his RR (i think it was a RR) into our local garage with all sorts of problems,
found out when he had been filling up with diesel that it was infact bio even though the garage never stated that clearly.
cost him thousands in repairs, as the bio had made all the seals with in the fuel system swell and i believe it did something else funky too but cant remember now.
no, its potentially bad carma in any modern common rail injected engine and its got nothing to do with the seals, Ive done several posts on the subject, If you have no joy on them hit me up and I'll have a go at doing it again for you.
to summate
If you get perfect bio all the time and run nothing else that might contaminate the system all good. IF you get contamination the bio doesnt have the head room in its specifications to deal with the potential results of the contamination.The end result is all bad.
