Results 1 to 10 of 11
Thread: rear diff
    Rye or cranbourne
    rear diff
    does anyones disco have a rear diff that sits out slightly more on the passenger side then the drivers side,it was pointed out to me before a few months ago with my 16x8 rims,i have a rangerover diff not the disco one..just wondering if something is bent maybe???
    Feb 2005
    differant offsets on you rims??
    Rye or cranbourne
    no not that have tried the same set swapping them around still sits the same..
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    Our rear axle on the county sticks out abit on the passenger side.
    TIM.
    Box Hill, Victoria
    Is this in comparison to the front diff?
    If it is, it will be the front will be out of alignment due to P/h rod and lift.
    Dave.
    Oct 2007
    Quote Originally Posted by DaveS3 View Post
    Dave.
    Not shore but i know alot more mud gets throne up the passenger side
    TIM.
    Apr 2007
    Alice Springs NT
    Ahh but is it the diff thats sticking out further or could the body be ever-so-slightly skew on the chassis?
    In certain lights, after the right number of beers I swear that the left rim is closer to the line of the wheelarch that the right.
    One day I'll get to the bottom of it
    Jason
    Nov 2006
    Check you haven't bent one of the lower control arms or the mount on the chassis for them. Does the vehicle track straight or does it crab walk up the road?
    Nov 2006
    narellan, sydney
    I had this on my old defender, it was a bent a frame, found with a straight edge.
    Andy
    St Helena,Melbourne
    4.28 MB
    Dave.
    Bingo, the higher you go the more the PH rod will pull the whole diff to the left, you need an adjustable PH rod .
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
