Results 1 to 10 of 14
Thread: Creak in back of disco
    McDisco Guest
    Hey All
    I have developed a creak in the back of the disco after my recent Simpson trip. It is noticeable when going over rough terrain and when the vehicle flex's (ie articulating over stuff). It a D2.
    At first I thought it was my cargo barrier and drawer system. However I have tightened everything up and it still creaks. I thought it might have been the new steel bar I fitted to the rear, but this should be causing these sorts of sounds.
    It actually sounds like creaking panels or trim, as if when you flex it is rubbing. Any ideas? I have heard of cracked chassis', B pillar cracking and roof cracking as well. Could it be one of these? What should I look for?
    Anyone else had this symptom?
    Angus
    Jan 2008
    4510 QLD
    Hey Angus, how load is the noise? After my Simmo crossing last year, bulldust made my tail lights creak in the body panels. Removed them and cleaned throughly and no more noise. The noise was noticable in the car when moving and it was between a creak and a squeak.
    Oct 2007
    Ballarat
    Try a bit of grease on the catch or bolt where the rear door locks onto the body. My D1 creaks from this when it gets dry.
    NSW SW Slopes
    After Madigans, mine had creaks caused by a broken rear coil spring and a back-seat door stay that needed lubricating.
    McDisco Guest
    Quote Originally Posted by jmkoffice View Post
    Hmm...yeah that makes sense. There is a lot of dust back there...will check it out.
    Will look at that too...
    Quote Originally Posted by pawl View Post
    Yeah I remember you saying this Graeme...I have thought about it. Will have a look, but it sounds more like a body creak.
    Angus
    Check for cracks in the chassis behind the coil mounts.
    Ellendale Tasmania.
    Quote Originally Posted by Tombie2 View Post
    This Angus is where i'd look too, that's where mine cracked, from what Bruce Davis told me and looking at it, it seems it was caused by the car continually hitting the bump stops, but ithink it started after hitting a washout on the road too the Dig Tree, it was a big hit, cause it set the Inersia switch off
    I also broke an engine mount too
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    McDisco Guest
    Quote Originally Posted by Redback View Post
    Baz.
    Any idea of cost for fixing something like this? I hope its not this...
    Angus
    Tuross Head NSW
    Mine (D11 2003) always had a slight "squeek" from somewhere atthe rear end, never checked it out, but a recent trip to Fraser and it developed a real loud "squark"-- sorry about the sound effects--- when going over speed bumps and before having a good look went back to the "squeek".
    I suspect dried out and ageing rubber bushes, will check all this out soon and I hope thats all your probs.
    2016 SDV6 SE Graphite "Pearl"
    2003 td5-Auto--- sold
    1992-200tdi Man---gone.
    If none of the other possibilities in the previous posts, check for broken/cracked body mounts - look carefully with a good light, around the body mounts on the rear cross member and the sills in front of the rear wheel arches.
    IMHO, Disco's are not as robust as classic rangies in these (and other) areas.
