Thread: Pilot Bearing Size
    Pilot Bearing Size
    I am looking at buying a proper clutch aligning tool suitable for a Series clutch. I have an old clutch friction plate to measure the size of the spline from, but I need to know the internal diameter of the pilot bearing. This will be the same as the external diameter of the gearbox input shaft.
    Aaron.
    Free Again Thanks Dan
    Quote Originally Posted by Aaron IIA View Post
    Aaron.
    Yes good idea but , You can use a input shaft out of a old gearbox for a clutch aligning tool
    Plenty of other things one can use such as a 1/2" socket extension with electrical tape wraped around to locate the clutch plate or just use your eye i have been known to use these in the past with no ill effects
    Essentially what I wanted to do, was buy a $5 plastic dummy gearbox input shaft. I know what size spine I need to look for, but I need to know what size the external diameter of the end of the shaft needs to be. If anybody has a gearbox that is currently not in a vehicle, could you please measure the diameter of this shaft for me. My gearbox is currently in use, bolted into my vehicle.
    Aaron.
    7/8" = approx 22mm
    Jan 2008
    Goodna QLD
    the bearing shaft is 22.1mm dia, 27.5 long. And the ext spline is 28.2mm dia.
    I would recommend making one from steel, as it is handy to tap with a mallet for fine adjustment when the pressure plate has a touch of tension, before tightening/torquing. If needed i can machine some up.
    I use a cut down shaft
