Thread: Water in Fuel
    Kalamunda, Western Australia
    Water in Fuel
    Gday guys, we had the water in Fuel light come up on the dash of our Td5 Disco today, it was only serviced 5000 ago and had all new filters fitted etc... I haven't had a chance to look around under the bonnet yet but is there a drain tap on the filter somewhere on the Td5s or is it back to the dealer again for more $$$$ to part company?
    Shano
    Oct 2003
    Montrose, Vic.
    Hi Strange_Rover,
    Being a recent convert from V8 to TD5 I am no expert... but pretty sure you want the separator you will find under your right rear guard... bottom of the pump.
    Also I was told that this can be regular fault with these - many give fake positives ... could be wrong - but good chance you have nothing to worry about.
    Cheers, Mark
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
    Thanks Mark, might pop my head under there tomorrow and have a quick look.
    Shano
    Kingston, Tassie, OZ.
    Shano,
    Drop the drain from the bottom of the filter and drain it into a clean container. If no evidence of water, a new sensor is required These DO fail at times, and usually just after being taken off to be drained out and re fitted again
    I've had to supply a few that either broke when being unscrewed, or did as yours has done- stayed on after servicing.
    JC
    JC, thanks for your input, is it an expensive sensor to replace?
    Shano
    The fuel / water drain is part of the sensor on the bottom of the fuel filter (right rear wheel arch)
    To drain it, you "carefully" turn / undo the hole thing (sensor) anitclockwise until it allows fuel / water (if any) to drain out. It has a machined slot in it that when its lined up the fuel can flow out. If this puts the light out, then great, if not just disconnect the plug, tie it up out the way and forget about it.
    You then have 2 options, leave it as it is, as they are common to give "spurios" messages, or simply replace it on the next filter change. They cost about £20 over here......
    I do know of dealers who have simply disconnected it and tied the loom out the way.
    DO NOT overtighten it back up, as they can shear off easily !!, and then you will have no vehicle to go get another one
    Worth also checking that the plug / loom connection is clean and makes good contact, may just be a dirty connection.
    the td5 has a combined filter/seperator element on the right hand side in front of the rear spring on the outboard side of the chassis..
    its hidden behind a plate thats held in place with a speed bolt remove that unhinge the plate and you'll see the filter... on the bottom of that is a threaded plug with a bunch of wires, trace the wires back to a quick connect plug. disconnect that and then carefully, very very carefully unscrew the plug, theres no need to undo it all the way once it starts leaking your set, catch about a coke cans worth of fuel then do the bung back up and replace the wiring and the cover.
    TD5 filter drain procedure complete, I do it every 10,000 Km and replace the filter every 30K Km.
    Yours is in a strange place then
    Williams West Aust
    Hi Shano
    They are well known to be faulty.
    Does yours even light up when the key is turned on? Mine dont,then again neither does the oil pressure light!!!
    Mine flickers on just before the fuel needle reads 1/2 then shuts up again.
    Ignore it,would have to be real dodgy fuel to be full of water already.
    Pretty sure the later D2s had it replaced with no sender.
    Goodluck
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Brisbane,some of the time.
    my 04 td5 doesnt have one,it was deleted on the later models.the 99&02 ones i had did have them ,but i never saw the light on ever.
    i would do what blknight said & you should be ok,unless you get unlucky
