Results 1 to 10 of 35
Thread: Defender storage spots
    May 2008
    Horsley Park, Sydney
    Hi, I have gone from a S2 Disco to a Defender again recently. Where do others mount a fire extinguisher and where do you keep the winch controller so they are easily accessed. Our cubby box in the middle has so much junk belonging to SWMBO I would never find the controller there. Thanks, Erich.
    dmdigital's Avatar
    Erich, good questions and I look forward to the answers!
    I've been playing around with spots for the fire extinguisher since we got the new Defender and I am still at a loss
    For the winch I'm thinking of keeping the controller with my other recovery gear in a box in the back like I do with the other Defender.
    Logan Village area S.E. QLD
    OK...here is the run down..beside the tool box thats under the backseat fits
    the fire ext nice and easy to reach when you open the door....the other side
    is the first aid kit again nice and easy.....the winch controller fits in the rear
    toolbox with the tree protector, snatch block and snatch strap...the other
    side has the air compressor.....any thing else
    OOOHHH I forgot you guys don't have tool boxes under your back seats do you
    aahhh well there's a thought for you...buy a 130
    AAHHH I must be getting over my cold ...whatch out
    Mrs ho har
    Series Landy Rescue
    Our FB Page..
    the winch controller lives between the seat and the cubby box and I have 1 fire extinquiser by the fridge at the rear door (on the side with the handle not the hinge) and 1 on the drivers side rear door on the little step beside the bottom of the seat...
    occasionally both extinguishers will be in the same place along side the rear seat or on the floor beside the seat belt reels but mine shift depending on load out. I used to have (but now cant find) the symbols for the extigushers that ID stick in the seal of the glass nearest the extinguisher.
    City & Avoca
    Quote Originally Posted by Bundalene View Post
    Ok - winch controller is in the overhead console - but its also a remote so pretty small, the 'wired' one is with the rest of the reco gear in a box in the rear. Fire Extinguisher - 1 under the passanger side storage area - near the access panel, doesnt knock knees or get in the way of the passanger, 2nd in the rear where the grab handle is up out of the way.
    Quote Originally Posted by The ho har's View Post
    Mrs ho har
    I have a toolbox under my rear seat, thats where the fire extinguisher goes and when the winch is fitted the controller will live.
    Hey Ho Har, which back seats do you mean? The front facing ones or the rear side facing seats?
    Oh I forgot you can't seat 8 passengers can you, time to upgrade to a County..
    Jul 2003
    I mounted mine to the rear door liner...I figured that this was the most accessible place in the event of needing it.
    The liner is dense plastic about 3mm thick. It is removed as shown on the attached sheet. There is also a clip in the centre of the panel not shown on the diagram.I used 5mm screws and lock nuts with large washers on the backside.
    Hopefully it will cope with the rough and tumble.
    I also fixed the hold open spring mentioned by timNZ in the wheel carrier topic while I was at it.
    Mahn England
    Ex 300Tdi Disco:
    Sydney, NSW
    Question
    Fire Extinguisher - Is it the law to carry one in Oz???
    I can count on one hand how many Land Rovers Ive seen with an Extinguisher in... and mine's not one of them!!
    Jon
    Regards,
    Jon
    Christchurch NZ
    Ah the joys of owning a Defender!
    I have the extinguisher where the factory put them, passengers footwell kick panel. If I need to I can reach it from the drivers seat. For the winch remote it lives in my recovery gear bag under the back seat, only have to undo the zip 6" and out it comes, you know what I mean, dont need to lift the seat. Under my back seat lives my gumboots, compressor, camp stove, wet weather gear (raincoat and leggings) and recovery bag (snig chain,9m strop, tree protector, snatch block, gloves, shackels and winch remote) and full size shovel. All this takes up no room and cant be seen from outside the truck. Gotta love Defenders
    1995 Defender 110 300TDI :D
    1954 86" Series 1 Automatic :eek:
    Ex '66 109" flat deck, '82 109" 3 door, '89 110 CSW V8, '74 Range Rover, '66 88" soft top, '78 88" soft top, '95 Disco ES V8, '88 Surf, '90 Surf, '84 V8 Surf, '91 Vitara.
    dmdigital's Avatar
    Quote Originally Posted by Yorkshire_Jon View Post
    No, but you never know when you'll need one!
