Never heard of this being done. Mostly you read of people going the other way - fitting windows to solid side panels.
Even more to the point - you don't give your location, so I assume you are in Australia, and to the best of my knowledge, no Landrovers have ever been sold in Australia with blank side panels in a hardtop, and I am a bit at a loss to know why you would want blank side panels. Also could possibly require engineering approval, although since the S2a was mostly sold prior to ADRs, it is a bit difficult to see it being a problem, except perhaps following an accident where poor visibility back and to the side could have been a factor.
But getting back to the original question - as far as I can see, it would work, but would be difficult to get a neat job of the join between the filler sheet and the side. it would be possible to fill the join, but seeing it is a completely flat panel, I doubt it is possible to make it completely invisible. The "proper" way to do it would be to replace the entire panel - it only has simple bends, so it should not be that hard. What I would do, if I had to, would be to simply replace the glass with an aluminium panel cut to size and held with the same rubber. You see this with factory (or at least dealer) van conversions of some Jap station wagons.
