Thread: Non Flashable too Flashable ECU
    Ellendale Tasmania.
    Can you put a flashable ECU from the D2a TD5, into the Early Disco 2 TD5
    Sorry if it's been asked before
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    Melton Victoria
    Yes the later ECU can be used in the early disco. An ECU from a auto can be used in a manual but most manuals have an the ECU that can't be used in an auto.
    You would need to have the ecu programed to suit your throttle switch (2 pot or 3 pot) as well as the injector codes.
    Rob
    Kingston, Tassie, OZ.
    All that is available to buy new now is the NNN prefix flashable ECU. I would say that there shouldn't be a problem, making sure the D2 is the same configuration as the donor ECU, IE auto / manual etc.
    JC
    If you get a flash ecu
    NNN000120 it will work on defender and discovery manuals
    NNN500020 will work on the same
    NNN000130 Auto discoverys
    NNN500030 Auto discoverys
    NNN500250 manual discoverys.
    The auto types will work on the manual cars butmay show some fault because the CAN system is otneeded on the manual version cars.
    You will also need to make sure that the ecu is programed with the correct fuling files as they are different from EU2 early cars toEU3 later model cars, again they will runon eachother but some have side affects.
    The injector codes and security will also need adding to the new ecu.
    Regards Pete
    Ellendale Tasmania.
    Thanks fellas
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    Williams West Aust
    Thanks Pete.
    Are we able to programme the codes and security onto the new ECU using our Nannocoms????
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Yes your nanocom will make the injector codes and security.
    Regards Pete
