Thread: Explorer window on startup!!
    Garfield, Victoria
    I have been clearing my wife's computer of Malware, and everything seemed OK until I installed SP3!
    Since then, whenever she boots up, she gets a Window Explorer displaying the My Documents folder, which has to be manually closed. Nothing untoward in the startup list, and I am wondering where it's coming from.
    Anybody here experienced this problem? If there is a tech type who can analyse a HiJackThis logfile, I am happy to provide one.
    Any help would be appreciated.
    Lionel
    Something will be launching explorer against my documents in the startup sequence. This is in the registry. You can look at what fires up though using MSCONFIG, from the Run command.
    Logan Village area S.E. QLD
    GGGEEE that a bit techo for us lay peoples
    Mrs ho har
    Series Landy Rescue
    Our FB Page..
    Quote Originally Posted by The ho har's View Post
    Nearly 20 years in IT before I got a real job. How tek-neck-ill do you want it to get
    thats tek-neck-ill enough for me
    Mrs ho har
    ps- haven't chatted for a little while....been busy??
    Series Landy Rescue
    Our FB Page..
    Garfield, Victoria
    I cannot find any mention of Explorer in the Startup list in MSCONFIG. This was the 1st thing I tried. There is no apparent reference in HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Run either.
    What is the exact reference I should look for? It might not be as obvious as I think it is.
    Lionel
    Look in the registry for something like
    C:\windows\system32\userinit.exe,C:\windows\system 32\userinit.exe,
    in the HKLM/SOFTWARE/Microsoft/Windows/CurrentVersion folders.
    It could still be malware related though. Do a google search for "windows opens my documents on startup" there's a number of different reasons this can occur.
    Garfield, Victoria
    I have found in:
    HKLM/SOFTWARE/WINDOWS/WINDOWS NT/Current Version/Win logon/
    Name: Userinit, value: REG_SZ C:\Windows\system32\userinit.exe, C:\Windows\system32\\userinit.exe
    This is the only occurrence in the registry, and MY computer, which is unaffected by this problem, ALSO has this entry, but WITHOUT the C:\Windows\system32\\userinit.exe (with 2 backward slashes).
    What do you reckon? Is this likely to be the problem, and is it safe to delete the 2nd (2 slash) one? Needless to say I will bachup the registry first.
    Lionel
    Yep, I'd delete the second part of this entry and see what happens
    Garfield, Victoria
    Yes!! That has fixed it. Thanks heaps for your advice.
    Lionel
