Results 1 to 3 of 3
Thread: occasional stickin of r380 gear shift
    maitland
    it seems to happen if i get wheels skiping under load on rocks or reversing out of steep driveways in the wet (i have a part time conversion)
    i have 1st 3rd and 5th no 2nd and top
    i have thought it could be a worn selector
    after a little while it can be reefed into second and it drives normal untill the wheels skip badly again (it also happens if i use compression braking in 2wd down slippery slopes) any ideas
    the box was rebuilt20 000klms ago
    May 2003
    On The Road
    "part time" as in rear wheel drive only?
    maitland
    yep untill ilock the hubs and select 4wd (what used to be cdl)
