Thread: Rear main seal TDi300
    Jul 2008
    Looks like my rear main seal staring to leak ( O Joy). Had a poke about as to motor out or transmission out. The V8 classic I had was relatively easy but this 300 looks like a lump of a thing. I have pit in my shed if i go the transmission way. Looks like its hard one way and differcult the other.
    Whats best or more to the point the easy way. Its a Auto
    Thanks Ray
    St Helena,Melbourne
    4.28 MB
    I haver never removed a TDI but have a 3.5 and i find it easiest to move the engine straight forward rather than remove the t/c and g/box.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Somewhere else, QLD
    A couple of things -
    1. If the leak is at the junction of the block and transmission bellhousing, then it's not necessarily the rear main seal. The last main bearing cap (that usually holds the seal on a old v8) has two rubber t-pieces on the sides. I had mine go - and you can replace them in situ, sump off. But it is difficult and you have to use a fair amount of good oil proof silicone on the face that joins with the rear main seal, and really clean the mating surfaces of the sump so it seals as per spec.
    2. If it is the main seal, it may be possible to move the gearbox backwards on a trolley jack, (after taking off the handbrake assembly) take the flex plate off and replace the seal. Fiddly but do able. If you do replace the seal, consider using decent silicone (I use dow corning 732), doing the 2mm bead and wait 5-10mins routine, and discarding the supplied gasket.
    3. If you have a shed and an engine crane forget what I said and just take the engine out.
    Jul 2008
    Quote Originally Posted by langy View Post
    Thanks for the response, was aware of the possible side seals on bearing cap & yep Ive got the means to lift motor out, & figured that was going to be the best way just thought I might be wrong. Fact is my patience with the Disco is wearing thin, Ive had it 3 years & spent more time on it than all the other vehicles & gear put together.
    Ray
    Oct 2007
    sunny melbourne
    I have taken your tip and removed all the bits (engine in)to get to the seals on the bearing cap. Any idea how to loosen the cap once the side bolts, starter motor etc have been removed. i reckon you are right about this for various reasons.
    Loyd
    Somewhere else, QLD
    Tap cap with hammer. Serious. Use a small hammer, and gently tap it on the side and it will fall out.
    You're going to need a couple of bits of plate (steel or alum) and a g-clamp to get the cap back in once the t-pieces are in. Much like compressing piston rings, if you compress the t-pieces, after having smeared the sides of the cap with 732, then the wet silicone acts like a lubricant and you should be able to tap the cap in without stretching the t-pieces too much. Use plenty of silicone against the face of the cap that butts onto the main seal, and it should work. My sump is still OK (and it's been almost a year)
    Oct 2007
    sunny melbourne
    job done
    The job is done.....no leaks (for now!!)
    Mine is a 2003 v8 so may be different slightly but the principle is the same. I had to make a bracket/handle to bolt onto the sump boltholes to remove the bearing cap but it worked.
    Apart from removing the starter motor to undo the side bolts on the cap it went smoothly . Thanks again
