Results 1 to 10 of 13
Thread: A Ghost in the Machine....
    tassiedisco Guest
    OK, guys....Here's one for ya all!
    My D1's brake lights come on at random times. Nobody in the vehicle; lights off; key out; doors locked or unlocked; no movement either in or outside.
    My gut feeling is that it's a malfunction in the alarm system, but I can't figure it. Any ideas???
    Melbourne, outer South East
    That is wierd
    Just confirm please it is the brake lights and not the indicator lights ?
    tassiedisco Guest
    Brake lights
    Definitely.
    Jun 2008
    don't think it is your alarm, my guess is your brake switch, on your brake pedal, it is powered all the time, and if shorting will light up
    Do you have a trailer plug on the back. If so check there isn't a short. Other thing to check is the brake peddle switch especially if an electric brake controller has been (or is) fitted.
    tassiedisco Guest
    Electric brakes
    Yes, it does have an electric brake controller. I'll check it out tomorrow (if it isn't raining )
    Cheers.
    tassiedisco Guest
    It's raining
    but being a farmer, I can't complain
    Quote Originally Posted by tassiedisco View Post
    You must be on the east coast. It never stops raining on the west.
    Jimboomba, QLD
    I have read that some of the older Tekonsha brake controllers do this. I think the solution is a new brake controller.
    -- Paul --
    | '99 Discovery Td5 5spd man with a td5inside remap | doesn't know what it is in for ...
    | '94 Discovery Tdi 5spd man | going ... GONE
    Quote Originally Posted by awabbit6 View Post
    If you've got an older faulty one that you are throwing out, may I have it to look at? (I'm an electronics tech.)
