Originally Posted by
series1buff
Is there an auto electrician out there ?
The RF 95 junk regulator was a standard fitting on myriad Uk cars from the late 1930's to mid 1950's , from MG TC's to Morris Oxfords. They don't last that well with age .
I have one here that has every fault you can imagine. The field resistor was high.. I soldered in some more resistors across it . It now charges Ok, but the cutout is very uncertain of what it wants to do. On the test bench, with a variable supply, it cuts in at about 9 volts .. no adjustment will change its behaviour. I suspect its got shorted turns internally. When its in the car, it won't release or open at idle .. it's stuck on .
Any ideas
BTW new production repro RF 95's are availabe at 95UK pounds.
Mike
It could be as you suggest shorted (intermittently) turns, but I would inspect it very carfully to make sure that the armature is moving freely, and not getting partly stuck (I can't visualise how it could, but then I don't have one in front of me - perhaps something sticky on the stop it is released against).
Failing that, I would try and get hold of another old one and start from there!
(my 2a now has a S3 alternator)
