Results 1 to 3 of 3
Thread: td5 didnt start first time today
    Jumped in the TD5 to go to work today and it started for all of 2 seconds then stoped. It took several attemps of cranking it over before it started.
    Its running well and it is the first time it has done this.
    Is this a sign of something failing like the fuel pump?
    Id start checking electrical stuff first and the drain valve on the fuel filter.
    Thanks I have a new fuel filter so I will do that tomorrow, started allright after work so in the morning I will give it a check over and may as well do the oils as well.
    Cheers for that Dave
