Thread: power for my laptop
    laidley queensland
    Cool power for my laptop
    Hi just bought a new laptop,its a ACER Aspire 6929G,and would like to take it way when I go camping......I can watch DVD,on it...as well as checking my emails....which is the best way to charge the battery
    1..buy a 12v dc connector,for my cigarette plug,to connect to the laptop.use some think else..?????..plus, were is the best place to buy one from...any good advice would be appreciated
    I have laptop charger that I bought from Jaycar for $49.95. It has all the voltages that most laptops run on and comes with various common connectors. It plugs into the lighter and works well.
    Melbourne, outer South East
    Two options
    1. get a 12VDC-240VAC inverter and plug your standard laptop power supply in to that. Some say you need a pure sine wave inverter but mine runs fine off a cheap $80 300Watt modified sine wave from SuperCheap.
    2. get a proper 12V DC-DC converter specially made to run your laptop off 12V. This "up converts" the 12V DC to whatever your laptops takes.
    You can't normally just plug your laptop straight in to the 12V DC. ( they seem to need 15-19V or thereabouts )
    Direct DC-DC conversion would be more efficient than 12VDC-240VAC then back down to DC. ( therefore more life out of your battery). 240V inverters normally also run a fan which can be a bit noisy.
    Acer may have a 12V car/airplane power supply ( check their website ) or you can get third party ones. Just make sure it supplies enough amps/watts to run your laptop. You can get an idea by looking on your AC power supply and see what wattage or amps output it is.
    NSW , Pennant Hills
    Quote Originally Posted by longreach View Post
    Hi Mate ;
    I bought one of these from JAYCAR
    Jaycar Electronics=
    mike 90 RR Guest
    Dick Smith will have something
    laidley queensland
    Quote Originally Posted by Disco_owner View Post
    Hi Mate ;
    Jaycar Electronics=
    thanks that's exactly what I was after,thanks for your help....keith
    I bought a Kensington adapter a while back, about $100, but it does everything.
    12v or 240v, comes with points for phones, ipods, all kinds of laptops, usb, etc.
    And tiny.
    Have a look at this thread -
    http://www.aulro.com/afvb/communicat...ur-gizmos.html
    Simon
    Goolwa SA
    As someone else said, if you buy a 12v DC adapter make sure that it can provide enough amps. For example, the Jaycar one mentioned supplies 2.9 amps but my laptop requires 4.6 amps. Projecta http://www.projecta.com.au/catalogue...4/asset_id/138make two models - 3.5 amps and 6 amps.
    Stephen.
    laidley queensland
    Cool
    Quote Originally Posted by StephenF10 View Post
    As someone else said, if you buy a 12v DC adapter make sure that it can provide enough amps. For example, the Jaycar one mentioned supplies 2.9 amps but my laptop requires 4.6 amps. Projecta Projectamake two models - 3.5 amps and 6 amps.
    Stephen.
    thanks...but where can I buy one from,the projecta web page dont show were to buy them
    ??......and I have just found out my lap top needs 4.7 amps,will 6.00 amps be to much....will it do any damage,having to many amps going through it.......I am only new to this sort of thing,so any help would be appreciated.........keith
    What about a cheap inverter like this one?
    It might be useful for charging other things too like your camera etc? It might be worth checking that any stuff you want to use charges on a modified sine wave output.
     2005 Defender 110 
