Results 1 to 8 of 8
Thread: Very strange external hard drive problem! :o
    Outer Sydney
    G'day all!
    I have a very puzzling problem with my Maxtor Basics external desktop hard-drive which has left me dumb-founded! Tonight i got a message saying 'the hard drive is not recognized and needs to be formatted', so i did, but after formatting another message came up and said 'Windows was unable to format the hard drive', so it seems that the hard drive is defective. The amazing thing about this though is that this current hard drive is the third replaced under warranty for the same reason in the past month!!!!!! Does anybody have an idea about what might be causing this problem to reoccur? My computer has recently been formatted and is running Norton internet security which i constantly update, so it should be virus free. The only files i ever put on the external hard drive are my thesis back-up files. I've never have a problem with my USB's in the computer.
    Thank you in advance!
    Edward
    Adelaide Hills - SA
    Have you got another PC you can plug into?
    If you get the same message, then probably the drive. If it works fine then you 'll have to trouble shoot your computer.
    BTW which USB port are you plugging it into? One of the front ports? Sometimes these don't have enough power available to run a big USB drive, so try plugging it into one of the rear ports (straight into the motherboard).
    What is the usage pattern of your drive? I had one fail that was constantly powered on/off rather than staying on with the computer.
    Also, what format is the drive? A file system like NTFS really doesn't like being shutdown incorrectly, so what you might be experiencing is file system corruption that leads to disk corruption.
    Also, if you're backing up your thesis onto a device and your experiencing these problems, I would recommend burning a copy of all of your research files to CD/DVD. You don't want this to happen a week before finishing your write up eh?
    Quote Originally Posted by Delta_Farce View Post
    <snip>
    And via email attachment, and some of the online backup services like idrive or adrive, and hard copy, and thumb drive, and...
    Simon
    Bayswater, Melbourne
    might seem silly - but make sure your formatting it using NTFS & NOT FAT32.
    Fat32 has a file limit of 2gig that it can copy & read, I got this error with a mates drive & finally I checked its formatting & found it was Fat32. There is a convert util from microsoft that can convert fat32 to NTFS - both types of file systems
    rbjt Guest
    I had a similar problem with an external USB/Firewire enclosure a year or two ago. It would work fine for a few weeks and then I'd receive the messages you have described. The problem ended up being related to the chipset used by the enclosure itself. It wasn't a Maxtor enclosure but they may use a similar chipset manufactured by a company called Prolific. The solution for me was to upgrade the enclosure firmware as discussed here:
    External Hard Drive Problems - Storage - PC Hardware
    I would have expected this problem to have been sorted out by manufacturers since then but it might be worth a look.
    Ryan.
    Outer Sydney
    Thank you everyone for your help!
    Yes spudboy I have plugged it into another pc and it still doesn’t work, and yes I am using one of the ports on the back of the computer.
    Delta farce -the hard drive is always on when the computer is on, and yes it is NFTS format. I can’t remember having incorrect shutdowns lately though. And yes I have numerous backups of my work!
    Thanks for the link rbjt! I’ll check it out soon!
    Cheers!
    Edward
    Quote Originally Posted by RaZz0R View Post
    Further to this subject. I found a problem with copying some files to my external drive. I eventually worked out that the the problem was that some of the files had characters in the name that are acceptable for ext2, but not for FAT32, and it was at that stage that I found that most if not all of these devices are formatted with FAT32. If this is the case with yours, I wonder if your problem started as a problem with the fact that it is FAT32 but then when you reformatted it as NTFS it became some obscure problem with the hardware that prevented it from working with the different format (that it had not been tested with).
