Results 1 to 9 of 9
Thread: how do I save a webpage??
    Eidsvold QLD
    I am trying to save a tutorial from a website which consists of approx 30 images spaced by instructions accessed by scrolling down the page,but when I save the document I either get the current screen I am veiwing OR all the individual images saved individually without text.This is the tutorial-
    BIG DADDY’S TOP END REBUILD
    I want to save it as it appears on the site, is it possible???
    Feb 2005
    just copy and paste
    when i pasted it in word the text colour need to be changed
    Today BIG DADDY will demonstrate how to remove the piston and cylinder of a big block Guzzi for inspection or replacement.
    The engine he’s working on is off of an 850 T.
    The steps he uses are the same for any big block Moto Guzzi from the late sixties to 2003.
    This job can easily be done with the engine in the frame. In this case it was removed for other purposes.
    Step 1.
    Remove the valve cover.
    Logan Village area S.E. QLD
    Crump
    Someone with more knowledge than me may say I am wrong but...........
    In edit hit select all....then copy....then bring up wordpad or something similar and paste. worked for me with no pictures though
    OK Weeds had a better idea
    Mrs ho har
    Last edited by The ho har's; 4th October 2008 at 03:14 PM. Reason: Weeds struck again
    Series Landy Rescue
    Our FB Page..
    Feb 2005
    pm me your email addy and i will forward the word doc
    Eidsvold QLD
    it all seems so simple now, thanks.
    I can print it as a PDF, but I'm on a Mac and using Safari. It could be an IE issue or even a printer issue.
    If you can't print to PDF then either (a) in Vista print to Microsoft File format thingy or (b) download CutePDF (its free) and use that.
    Eidsvold QLD
    yeh, but when I paste it into WORD, each image appears on a separate page, howd you get it all together??
    Feb 2005
    cannot help you on that one big fella
    apart from re-sizing every pics sop that two fit to a page
    Quote Originally Posted by crump View Post
    Crump what's you're e-mail and I'll send you it as a PDF
