5th October 2008, 06:05 PM
5th October 2008, 06:41 PM
No havnt had it happen to me but it is not uncommon on Diesels for things to rattle loose.
I would say that this is what has happend and then the bracket has worn through the bolts.
I have found plenty of loose nuts and bolts over my engine onver the years, the worst being an oil cooler line while going up a hill in the bush with nowhere to stop other than on top of a woopty do where I stopped, blocked off the track because of which which got up the nose of the ranger who had a copper with him.
These things happen but that is something else for us all to have a check of at the next service.
Thanks.
6th October 2008, 08:38 AM
Not on a 300 Tdi but I know Chenz had his alternator bolts fail on a 200
Martyn
6th October 2008, 08:50 AM
#4
must have been noisy!
sounds like fatigue and improper tensioning (too loose or too tight), as they are studs they could be buggers to get out
BTW, I believe there is a replacement a/c pulley/clutch bearing available through Karcraft (they wont be open today 'cause it's a public holiday there apparently)
it's good if there was no extra co-lateral damage
regards - Laurie
