Thread: Chipped TD5 with running AC pulls better - how it can be?
    Ruslan Guest
    Hi All,
    While traveling to the Fraser Island and back I noticed that doing around 100km/h with camper trailer a little easier with aircon 'ON'. The outside temperature was about 30-34 C, all windows and flaps were closed. According to Nanocom coolant temp 89.8-90.2 C, turbo pressure no more than 0.9. Overtaking trucks on long uphills was like a song - just a little more right foot and from 80km/h to 100km/h in a few seconds.
    Still don't know what it was. To check that aircon makes a difference I tried to do the similar exercise without it, and once it switched off, after about a half a minute I was loosing that sweet uphill performance. It wasn't bad, just normal what I used to and expect from such load.
    I'd say it is another nondocumented feature of the Tombraider's remap
    Thanks,
    Ruslan
    That's bizarre. I can't wait to try it!
    Where did you mount the nanocom?
     2005 Defender 110 
    Ruslan Guest
    Quote Originally Posted by Captain_Rightfoot View Post
    It was mounted only for trip next to UHF radio on top of the screen panel. I've started building PC computer with 10" touch screen a week earlier before the trip, so we have used GPS/OziExp/Destinator all the way.
    After a bit of research some ideas came up:
    - Closed windows/flaps help to reduce air resistance on high speed (well known fact)
    - Aircon electric fan helps to reduce intercooler temperature (???), so a bigger intercooler would be better, no words!
    - Aircon compressor mounting points loose or/and to check belt's tension
    Can someone think something else, please?
    Looked at your avatar, you've blocked the airflow with driving lights, like me.
    I think you're close to the money in saying the a/c fan is on, forcing a better airflow across the intercooler. But I can't say I've noticed an improvement.
    FWIW I think your TD5 is working hard at 100 kph, on those Nanocom readings. Mine sits spot on 88 degrees until it hits a long hill, then it can rise temporarily to 98 degrees.
    And at a steady 100 kph my boost varies from .6 to .9. Obviously changes according to headwinds, crosswinds, gradient. But never a constant .9 or so. Actually it can go up to 1.05, as the cruise control attempts to hold 100 kph up a hill.
    This is at a genuine 100 kph too, not a Defender speedo's 100. I've had a truespeed fitted, and its spot on with the GPS.
    Watching the Nanocom can be quite entertaining!
    Max P
    Ruslan Guest
    Quote Originally Posted by Tusker View Post
    Thanks for response, Max. The driving lights so good, I better live with them and drive slowly.
    You right, 100km/h on Defender is not real 100. To be correct I was doing 95-105 according to GPS, dropping to 70-80 before overtaking and accelerating up to 115km/h while overtaking. Only once I noticed boost went to 1.04 for second at 3010rpm when I was on 3rd (overtaking run-up uphill), and on 5th it never gone over 0.9 (0.3-0.9). So looks like it normal compare to your.
    Forgot to tell, the fuel consumption was surprisingly good. Lowest is 11.3L/100km towing camper trailer at about 100km/h, got it from 3 tanks one after other.
    Ruslan
