Sounds to me like you may have a short circuit somewhere, perhaps check the cabling from the trailer plug back to each brake hub for damage or loose connections?
Good luck, Phill
G'day,
Anyone around Northern Perth know anything about ALKO electric trailer brakes?
Not sure if its the actual brakes on the trailer that are the problem or the in car controller.
Symptoms: incar controller goes from "C" Conected to "NC" Not connected while driving, the brakes are still working - if I press the brake pedal the numbers come up on the controller but then immedicately goes to "NC" for about 10 seconds and then back to "C".
Anyone have any idea? I have checked the connection between the car and trailer - they seem fine and have sprayed with Inox.
I have never worked on these, so dont know what to look for
THX in advance,
LRH
Disco 4 SDV6 Auto
Disco 4 SDV8 Dual Cab Project
Disco 2 M57 Extra Cab Project
Foton Tunland Cummins ISF
Disco 1 3 door 4.6 V8 Auto
RRC V8 Auto "Classic" Softdash
RRC 300 TDI Auto
Disco 1 TD5 Auto Buggy
Disco 1 300 Tdi Auto Ute
SAME Explorer 70HP 4x4 Tractor plus Nell Loader
Subaru GDA WRX
Triumph Bonneville SE
Yamaha TTR250
Good luck, Phill
I think Martins Trailer parts are the distributors over here.
There branches are as follows:
Wangara are Northern Suburbs or Bayswater is closer to the city. O'Conner is south of the river.
Trailer Parts Pty Ltd
Bayswater
4 Katanning St
Bayswater WA 6053
9279 5777
O'Connor
81 Forsyth St
O'Connor WA 6163
9314 2222
Wangara
61 Challenge Blv
Wangara WA 6065
9302 2800
www.trailerparts.net.au
