Results 1 to 9 of 9
Thread: Cooper oil filters
    May 2006
    Sheffield Tasmania
    Cooper oil filters
    Moved to Tassie a while back and need to replace filters on my S1 td5
    and have been told that you cannot get cooper filters over here.
    So what do you Tasweigans use in your td5s, I can get Cooper Z1353 oil
    filters from T R S in Adelaide S.A. but would prefer to buy locally.
    Seashells
    94 hybrid Disco td5
    mcrover Guest
    I suggest you talk to JC (Justin Cooper) as if you ask any other tassy person, you are bound to get 2 different opinions
    Cooper or Coopers?
    Two different brands. See
    cooper oil filters Tdi 300
    Devonport, Tasmania
    G'day Hybrid disco
    Give these guys a try British Four Wheel Drive - Land Rover & Range Rover Parts Specialist, they are in Hobart. Their delivery statewide is quick and I'm sure I have had a Coopers filter from them in the past.
    Likethe others have said JC would know for sure the best place to source them.
    What part of Tas are you in?
    CheersAndy.
    Kingston, Tassie, OZ.
    Hi there and welcome to the state!
    What is the 'hybrid' part of the disco??
    In answer to your Q, I only use genuine LR filters, but I can get Coopers or Crosland , whatever you want.
    Where are you ?
    JC
    May 2006
    Sheffield Tasmania
    hybrid disco
    Hi Justin
    Thanks for the reply I am using Cooper Z1353 oil filters, as used by Triumph Rover Spares in Adelaide when they fitted my D2 auto box, the previous auto box was a S1 but owing to a problem lost third and fourth gears so replaced it.
    My 94 update disco was 3.9 v8 but as the motor was just about had it at 180k I had a replaced with a td5 diesel. ( bought entire drive train from radiator to exhaust pipe from a rolled d2 disco) fitted all except the auto box as then I needed a S1 box to get the speedo working.
    Fitted the S2 fuel pump into the original tank, the D1 bcu operates all the original gear inside the disco while a S2 ecu is for the engine management system.
    hence the hybrid name
    Seashells
    May 2006
    Sheffield Tasmania
    coopers oil filter
    Thanks Ron
    Wasn't aware of the two brands but after looking, the screw on canister is white, so thanks for the info, have had no problems so far.
    The oil filter z1353 is for td5 motors (have fitted one into my 94 disco)
    Seashells
    May 2006
    Sheffield Tasmania
    wrong oil filter
    Well seems that I have opened my mouth before engaging brain again
    the oil filter it seems that I require is a coopers not a cooper as stated
    thanks again Ron for putting me on the straight and narrow.
    Apologies to all and sundry it must be the weather causing all this brain strain since I came to Sheffield.
    Seashells (hybrid disco)
    WA
    Quote Originally Posted by hybrid disco View Post
    CooperS (with the S) make most of the OEM filters for Landrover. So a CooperS filter is likely to be better quality than a GUD/Ryco/Cooper filter.
