Results 1 to 10 of 15
Thread: Interesting LPG regulation
    Wheelers Hill, Melbourne
    I got a copy of the latest AS1425:2007 which is the standard for fitting LPG to vehicles.
    Just reading through there are a couple of regs that clearly are'nt known in the industry.
    1/. Where a vehicle is fitted with more than one container the vehicle shall be fitted with an additional red diamond on the number plates.
    2/. This diamond shall be an external metal plate not less than 1mm thick.
    3/. The colour shall be reflective red and have only the letters 'LPG' in white at least 10mm in height.
    Another requirement is that the test dates on the tank can be clearly seen where the container is installed.
    Food for thought
    Free Again Thanks Dan
    Yes the lpg metal badge is a known regulation ,Where have you been hiding
    And you are meant to have a lpg badge per tank ,this is for the fire fighters or emergency crews in case of a emergency ,so they know how many lpg tanks they are dealing with
    Even the cars we convert to lpg at work ,that are only run in a controled enviroment and never see the real world must display the badge on the number plate incase of a emergency
    Safety Bay
    If they have a cover it must not be locked and the shut off valve must be easily reached.My defender is going to be used as the trial vehicle when it gets fitted with D/Gas and it seems that it has to be fitted with rigid pipes from the tank to the engine bay and they must be covered and firmly attached to the chassis.There is no such regulations if you want to fit a couple of 9kg bottles to the front of your van though. Pat
    Yass NSW
    Interesting. A mate bought a small truck with three gas tanks. Onlt has the single lpg diamond on the numberplate.
    Quote Originally Posted by rangieman View Post
    Nearly Chris
    The wording is as from the book, so only two badges to nominate more than one tank
    The funny thing also is, yes, the valves need to be 'readily accessable" but only for servicing. No mention at all about manual emergency shut down. I guess they think the automatic shut off when ign off and/or engine shut off is sufficient. And who is gunna try for a medal anyway??
    My take on the reg is for seperat tanks like the fuel tanks in fozzy since each tank is independant of the other its 2 tanks. If they were LPG tanks Id need 2 stickers.
    But, If I had a hose/pipe on them that joined them together then they would be 1 tank and again if LPG would only require one sticker.
    East-South-East Girt-By-Sea
    1.20 MB
    My take on the regs and I know nothing, is that (at least in NSW) you can't have them operating independant of each other. I asked, because I wanted to have them running as main and reserve and was told it's not permitted. But I would still need multiple stickers.
    Diana
    Diana
    Yes, there was a concern that shutting off the 'spare' tank from supplying fuel to the engine might lead to its overfilling, as the AFL valves could allow the second tank to take a litre or so each time you filled up. After a while you would have a 100% filled tank. So all tanks have to fill and empty together. Which makes me wonder when this 2nd sticker rule came in. ? Think of all those scuba tanks under rangie's & disco's
    r.over Guest
    Quote Originally Posted by PAT303 View Post
    I think that you will find that this only applies if your tank and converter are also attached to the chassis. A body is usually rubber mounted to the chassis. Therefore there can be movement between the chassis and the body. You must use a flexible gas line wherever movement can occur. So wherever the pipe goes from the body to chassis or back again you must have a section of flexible hose.
    1.20 MB
    Quote Originally Posted by DeeJay View Post
    ....Which makes me wonder when this 2nd sticker rule came in. ? Think of all those scuba tanks under rangie's & disco's
    Is a scuba tank the same as a manifold tank or several tanks plumbed in together?
    I have a manifold which I believe is also called a "scuba" and even though it is multiple cylinder arrangement, they have pipes welded between them so act as a single tank.
    Diana
