Results 1 to 10 of 14
Thread: Roller Rockers
    Foot of the Otways
    Roller Rockers
    Howdy Guys , Just doing some dreaming on the net about building one hell of a V8 and come across roller rockers . Are they what they are cracked up to be ? Do they make a motor run smoother and better ?
    Yinnar South, Vic
    Not stinky little rover motor
    Only necessary for big cam big HP applications
    Padstow NSW
    yep what he said.
    wouldnt waste me money on em for a rover.
    they do cut down on friction and are designed for hi valve spring pressure and hi lift cams. ive always run them on all my ''other'' motors.
    cheers phil
    Moruya Heads/Sth. Coast, NSW
    Quote Originally Posted by rovercare View Post
    Would'nt aftermarket Roller Rockers be Cheaper to buy than original L/R rockers, esp. if the originals were buggered, Regards Frank.
    Yinnar South, Vic
    Quote Originally Posted by Tank View Post
    Along with an aftermarket pedestal shaft??, I'd imagine someone is making them, but they're likely to be making aftermarket standard rockers to
    Foot of the Otways
    Thanks for the replys guys . I wouldn't want to spend the money on a rover motor . I was thinking about putting roller rockers in a 308 that will have a big cam in it .
    Padstow NSW
    Quote Originally Posted by Fusion View Post
    thats a differant story! in that case ide deffinatly go the rollers. there are heaps of good ones out there that wont break the bank either.
    cheers phil
    Central Queensland
    long story short, if you're building a serious engine, the easier you make it for the engine to do its job, the easier it is for the engine to make good power reliably and consistently
    dont skimp on stuff, try to use known brand stuff, the last thing you want is for the $80 set of no name lifters to fail, possibly taking out the rest of the engine with them
    Avoca Beach
    OK here is avariation that I have wondered about.
    Has anyone seen a roller cam in a Rover V8.
    You can get a roller cam and lifters for a Holden V8, and the lifters are the same, so why not a roller cam and lifters for a Rover V8.
    The lifters for a roller cam are paired to keep alignment with a steel bridge, but it should be relatively easy to make a slightly different size bridge.
    This woulds alleviate one of the biggest problems.
    Regard sPhilip A
    I have thought about needle rollers inside the rockers withsome kind of oil seal each side and a drilled oil spray hole towards the valve stem........ but I shouldnt say too much in case someone steals my idea........ DAMN!!! Just gave it away!!
