Results 1 to 3 of 3
Thread: Any good places to get Defender Inspected?
    getafixnow Guest
    I am looking at a Defender in Artamon in Sydney.
    Does anyone know a local place to have it inspected prior to purchase?
    I went for a test drive and found a very slight lag in first, followed by a slight clunk in the Rear Diff? before moving off. The same when in reverse.
    Has anyone had any experience with this happening in a Defender X-treme?
    Once the car yard has it repaired will there be further problems?
    Cheers if anyone can assist my enquiry.
    Darren
    WA
    Drivetrain clonks are fairly common, could be:
    A-arm ball joint
    rear drive flanges
    Gearbox output/t-case input splines
    If you search you can find out how to check for each of these and how easy or $$$ they are to fix.
    If you are lucky, someone on here may be willing to check it over in return for a cold frothy reward...
    Qld.
    I fixed a minor drivetrain clunk (thanks to advice from this forum) by tightening the prop shaft bolts - only 1 was slightly lose - but it totally sorted the issue.
    How about NRMA to look at the vehicle?
    2007 Defender 110
    1993 BMW R100LT
