Double Carden Joint
As we know the UJs on the front prop shaft of a 101 come in for a hiding because of the excessive angle between the gearbox and front diff. This requires more regular changing of UJs (the army rated their life as 17,000km) and the acceptance of some vibration from the front end. As the front end of a 101 is unique I would have thought they would have designed the front axle housing so the diff was tilted up to ease the angles - but it is too late now.
While there seems to be failures of the double carden joints in later Discos (because of the A/C drain?), I have not really heard of it in the Series 3 Stage 1 which has a double carden joint on the front propshaft (gearbox end?).
Has anyone modified their front propshaft on a 101 to take a double carden joint and if so how does it go?
