Results 1 to 10 of 25
Thread: Defender additions
    May 2008
    Horsley Park, Sydney
    Defender additions
    Just finished installing a stainless water tank plus axe/shovel holder to the Defender - took a bit longer than I planned. The water tank holds 45 litres - yet to add a breather. (Newer shovel coming before the next outing).
    A fabricated stainless water tank – very tight fit
    View from underneath. The exhaust, mud flap and side guard required new brackets
    Always good to add improvements - gives more storage space inside.
    Cheers, Erich
    Adelaide Hills - SA
    Looks very nice.
    On a separate topic: Are you involved with the "Son_of_Bundalene" Land Rover eBay shop that I was browsing around earlier today?
    May 2008
    Quote Originally Posted by spudboy View Post
    Yes, Andy is our son.
    Adelaide Hills - SA
    Uh - OK, I thought there might be some connection
    i'm sure erich hasn't got random son's lying around the country.....
    Erich you have too much time on your hands
    Very neat job!
    I'm not sure about the filler at the back though, has it got a quick connect fitting?
    Does the axe or shovel handle move against the back quarter window?
    May 2008
    I bloodywell hope not !!!
    Mrs. B
    May 2008
    By the way, what have you been up to today in Gove???
    May 2008
    The filler isn't finished - yet to add a breather and an easier opener. The shovel handle is locked against the roof gutter and the axe is fixed tightly and clear of the window rubber by about 20mm - should be OK even on the corrugated Gove roads
    Outer Sydney
    Is that a valve for a poly-air i can see on the back? How do you find them? I'm currently tossing up whether or not i should buy em. Thanks!
