Results 1 to 6 of 6
Thread: Backing Plates
    Nundle
    Backing Plates
    Does anyone out there in S2 land have a pair of front brake back plates for a SWB 2A ie 10" brakes. I need a couple to replace the modified ones on Castrol.
    Thanks in advance.......or should that be in hope.
    Numpty
    REMLR No 143
    I'll check the spares stock out the back...
    Im pretty confident I should have a complete set of ready to bolt in series III stuff BUT if your after originality IF I kept the parts off of kermit before I started the mods project then yes I have a set.
    Nundle
    Thanks Dave. I will await your search results.
    Perry
    Numpty
    REMLR No 143
    the SIII stuff I can confirm I have.... (and I have an extra set on a rolling chassis I dont need that I know works well)
    sII stuff will require more digging.
    Nundle
    I'll be back home again in a couple of weeks, but if the S3 ones fit (and are not too different) they will probably be OK.
    Numpty
    REMLR No 143
    sIII are 11 inch but if you change the whole braking system......
