Results 1 to 10 of 15
Thread: Attn: Blknight.aus
    Oct 2008
    Heart in the Deep Nth of FNQ,Body in the Deep Nth of Brisneyland
    Attn: Blknight.aus
    G'Day Dave, Dave here ; ))
    Thanks for your posts (life story). It's nice to see someone who has mastered the art of messing with the system! Just a quick question: would you be able to check the specs for Truck, Surveillance, Lightweight, Winch, MC2 (RFSV, pictured(points at avatar^) for me ? I have in my memory that they were supplied to us with 4.11 diffs, rather than the 3.86(?) of the GS. I assume that the '98 on SRVs would be the same, though not the ADGs buggies.
    Thanks in advance, Dave.
    Jun 2003
    Launceston, Tasmania
    As far as I know the diffs are of the same ratio as the rest
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    WA
    Quote Originally Posted by DiscoDavo View Post
    The GS has 3.54:1 diffs, as would your disco (if stock). Like Phoenix, AFAIK all 4x4 models had the same ratios.
    Hay Point
    Diff ratios normal 3.54 but the RFSV had a different ratio in the transfer. 1.112 to 1 instead of 0.996..........I have the part numbers for these gears (hi ratio gear and center diff gear) if you are after them...................Bearman
    what they said...
    high range is lower, low is the same
    diff ratio is 3.54:1
    its either the SRV or the RFSV that gets the 6 gear front diff.
    some other added goodies over a GS like sway bars a winch, digital trip meter, more spares, dual batteries, dual tanks... taller suspension
    there are mission kits for them that change the configuration but most of that is bolt on stuff but a couple include split rims....
    Oct 2008
    Thanks Fellas, that's interesting.
    Bearman, I would love to require the parts, as it would mean that I had had the $60K required to purchase the ex-SASR Support group Fund Raiser RFSV (maco, PC tarps-no fading! ~ 30K kms on the clock.... sorry , am tearring up now :...(.
    But I digress..
    So, they were fitted with an 'under-drive'? Makes sense considering the loads we carried for extended patrols (a 200lt drum fits between the rear seat and 'Rollbar', but shh, don't tell) and, IIRC, we had no anti-roll bars to extend articulation. With the pedal stop wound to the floor V-Max was 115 down-hill!
    Beautiful off-road, wallowy on.
    Cheers, Dave.
    Hay Point
    Yeah, would be great to get hold of one. I have a set of the RFSV t/case gears to fit the tapered roller intermediate shaft but havent got around to using them yet. Next time I do a big trip up north I am going to fit them and see what difference it makes fully loaded. The 996 ratio is a little high fully loaded including trailer and boat on top even with the turbo. Anyway we can always dream. Regards...Brian
    Kingston, Tassie, OZ.
    Quote Originally Posted by Bearman View Post
    Hi Brian, I'm running those ratios at present and wil swap out to .996:1 shortly. I find them excellent with the camper trailer hooked up and fully loaded when hills are involved, but the revs are still too high at 100km/h on the flat cruising for my liking. Perfect at 80, but a pain if you want to overtake at 110, as it is almost on the governor(125 is TOPS)
    I'm running 33" tyres,(255/85/16) BFG mudders.
    I don't have a boat on my roof, (If I had one it'd probably be on the trailer anyway because I am too short to reach that high), so this will probably be to your advantage to try them.
    JC
    gee is that all you managed to squeeze in there?
    and 115 is about right for on the govner running.
    WA
    What are the army engines governed at Dave??? On 7.50's, with 1.112 gears, that speed would only be right if they were governed at 3200 rpm.
