yep fans will run until,,,
after warming up,, if the temp guage moves AT ALL,,(should sit halfway)
there is something wrong![]()
i have d1 v8, after turning off the iginition you can hear the fan still running. is this normal? it has been getting a little hot, not over half way though.
last time i waited 5 mins and it didnt turn off so i took out the 30am fuse from under the bonnet. then replaced it and the fan stopped.
this hasnt happened b4 onlt twice in last 2 days,just want to be sure.
thanks
'97 to '07. sold.![]()
As pedro said, they will run until the engine cools down, i wouldnt worry. Be more worried if it doesnt come on at all
The 4wd Zone/Opposite Lock Bathurst
263 Stewart Street, Bathurst, NSW
http://www.the4wdzone.com.au/
Discounts for AULRO members, just shoot me a PM before you purchase.
I'd be working out why it's done it.
when mt TD5 did it, the radiator was full of mud.
Slunnie
It's common but 5 minutes does seem like a long time. I'd say it's worth looking into.
well i have decided to do rad flush and also replace thermostat and gasket just to be sure.
is there like a breather valve or somthing to get a potential air lock out? on a lr?
i know commodores etc have.
On the D1 I filled when changing the coolant I filled the system through the actual radiator filler hole on top drivers side of the radiator - and also filled the overflow tank. On the D1 this filler hole can be used to bleed the system.
Electric thermostat faulty?
ok whats the capacity of a d1 v8 radiator?
11.3 litres manual 11.7 litres Auto
