I fitted mine under the drivers side mudguard, behind the headlight. The cables are relatively short and the solenoids are as high as humanly possible. Beside them is a Hella 1000 amp isolating switch, the key of which is spring clipped to my cubby box. The bonnet must be opened and the key inserted for the winch to work. I myself would not use a wireless remote, there are many storys of other peoples remotes working your winch inadvertantly
				1995 Defender 110 300TDI :D
1954 86" Series 1 Automatic :eek:
Ex '66 109" flat deck, '82 109" 3 door, '89 110 CSW V8, '74 Range Rover, '66 88" soft top, '78 88" soft top, '95 Disco ES V8, '88 Surf, '90 Surf, '84 V8 Surf, '91 Vitara.
