Results 1 to 10 of 18
Thread: How do you carry your rods on a plane?
    Padstow NSW
    im off to bowen on saterday for 11days of fishing,,,and my best mates wedding. im flyin up on virgin blue. have any of you fisho's ever taken your rods on a plane with you and if so how did you go about it?im wanting to take 3, one piece rods max diameter of 60mm and total length of 2.2m.ideas...cheers phil
    May 2003
    On The Road
    stormwater pipe?
    glue the ends on.
    Jun 2008
    McMinns Lagoon NT
    Oversize bagagge is no worries - you just get charged for it.
    Obviously you need to pack them in a tube of some description and make sure they can take a substantial weight being dropped on them, but as long as you do that well enough then it shouldn't be a problem.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Free Again Thanks Dan
    stormwater pipe?
    glue the ends on.
    Except one end which you use a screw on cap , other words you wont get your rod out of it
    May 2008
    Horsley Park, Sydney
    You can buy proper fishing rod holders from most fishing shops - I bought one last year - about $45 from Amazon in Wetherill Park
    No problems with the plane as already mentioned.
    Erich.
    stormwater pipe?
    glue the ends on.
    x3
    Bit of foam at either end.
    Simon
    May 2003
    On The Road
    Quote Originally Posted by rangieman View Post
    Quote Originally Posted by abaddonxi View Post
    x3
    Simon
    no one else can either---
    just chop one end off,, buy a new cap for the return trip,,
    what he said, just make the tube long enough to be able to saw a bit off, and throw the extra cap in your luggage for the return trip
    now the saw and the glue you may have to pre organise to be available at the destination.
    or cut the rods in half!!!!!!!
    Safe Travels
    harry
    Padstow NSW
    glued on at one end and screwed on at the other, i can drill a hole in the side and the cap and use a padlock to secure, that way no saw and glue needed! unless i loose the key
    thanks fellas!
    cheers phil
    Singapore via Melbourne
    ?I don't get teh glue on both ends bit... have you guys REALLY heard first hand of stuff getting nicked during a flight or by baggage handlers?
    I fly regularly, as in 2-3 times monthly internationally and never use locks (only Aussie tourists do in my experience). Never had anything touched, never heard of anyone else having anything touched and I live and work with literally 1000's of friends, colleagues and acquaintances doing the same thing - word would get around damn quick if it did happen!
