Results 1 to 10 of 11
Thread: 24 spline axels to aeu2522
    May 2008
    cairns
    i have a 24 spline true trak that i fitted to the carrier out of my 200tdi and was wondering if i can use the 24 spline axles from the defender to go into the county to mate up to the cv aeu2522 .as the axels are still in really good nick
    You mention 200Tdi, defender and county in one sentence like they are 3 vehicles, and made it hard to tell what you are asking about.
    AEU2522's can be fitted to most coil sprung rovers if you have the right parts e.g bushes and drive flanges. Just what is needed depends what the are going in.
    May 2008
    cairns
    sorry about the wording .my old car was a 200tdi defender and my new is a 85 county . i have taken the diff from the defender and fitted a 24 spline tru trac to it and would like to fit it to the county the axels out of the defender are 24/23 spline will they connect to the cvs in the county
    thanks for any info
    Yinnar South, Vic
    So long as they're 23 spline on the CV end, they'll fit, thought 200tdi defender was 32 spline, but never stripped a fender front
    Rangier Rover Guest
    Quote Originally Posted by defmec View Post
    So you are fitting a 24 spl fender diff and 24/23 shafts to a county with aeu2522 cvs . The aeu2522 are 23 spline.
    Tony
    May 2008
    cairns
    Quote Originally Posted by Rangier Rover View Post
    Tony
    yep
    cheers on the info guys
    Longmont, Colorado
    If you have trouble finding the 23X24 spline Axles for your County I make them. $400 plus shipping.. I know the exchange rate isn't so good at the moment but thought I'd toss it out for you..
    Freestyler Guest
    I have a 24 spline true track in the front of my county with Hi Tough 24 spline axle and drive flanges. I have been told you can put the Defender axles in the county and I will try that shortly but cannot say for cirtain.
    Jun 2007
    Hi Defmec,
    you should be fine with this set up,
    the 200 tdi CV's are long like the 2522's but they take the smaller 32 spline shaft so you can just fit the 2522's straight in with the 23/24 spline shafts no problem,
    N Qld,
    Can I use my STD 98 Disco front flanges on AEU2522 CVs???
