Results 1 to 10 of 25
Thread: 300tdi's with boost gauge fitted
    Feb 2005
    i have never driven a car with a boost gauge before
    plumbed it all up yesterday.....not so straight forward as i first thought
    i noticed that it doesn't take too much right foot for the gauge to whip around to 15/16psi
    is it because of the small capicity of the engine or turbo that makes it spool up so quick
    had a quick run on the hi-way tonight..........sits around 10psi @ 100km does this sound about right, any small high and she get up to 14/15psi
    i plan to make an adaptor up so i can can compare manifold pressure
    Where did you connect the pressure line to?
    Usual spot is to the plenum. Connecting it to the compressor outlet will tell you what the turbo itself is doing, but not actually what is in your manifold plenum which is more accurate of what is being fed into the intakes.
    Feb 2005
    at this stage its at the turbo
    from what i have read on here, fueling is controlled by the turbo pressure and pressure drop over the intercooler can be measured at the manifold
    i figure so long as i know what the pressure drop is its probably best to have it connect att he turbo most of the time so that i get an indication of fuel
    happy to listen and learn as i know bugger all about boost/fuel/connection points
    Kingston, Tassie, OZ.
    Hi Kelvin,
    At the manifold is better, as it is a true indication of the ACTUAL pressure available. Even better again is blocking off the fitting completely at the turbo, and using actual manifold pressure to control fuelling and wastegate operation by connecting it all up to the manifold itself. There is a handy plug already in the manifold that you can unscrew and either substitute for a designated hose fitting, or just drill and Gas tap the plug.
    10psi at cruise on the highway is good, 15 to 16 under load is good, this is why these engines are so fuel efficient also, plenty of air forced into them.
    JC
    Feb 2005
    Hi Kelvin,
    JC
    while driving to work this morning i was thinking about what would happen if i changed the plumbing so that the fuel pump receives its boost pressure from the manifold
    you have just answered my question, reckon i will give it a go
    NSW far north coast
    I don't think it matters where you read it from, at least at the T piece on the turbo you are seeing what the boost compensator and wastegate see. It's all relative.
    BTW, has anyone actually measured the pressure drop through the IC ?
    I'm curious to know what it is.
    FWIW I usually see around 12 psi cruising at 100km/h. Can drop to 10, but depends on road surface, head or tail wind, slight incline or decline, etc.
    NSW , Pennant Hills
    Thanks Rick ;
    I also didn't think it really mattered where you read the Boost pressure from , at the T-piece or the manifold , as long as the Compressor is doing it's job putting out a healthy 15-16psi of boost ,as long as all plumbing was intact .
    Would be handy to have both to measure pressure drop accross the intercooler.
    Edit :
    Kelvin 10psi crusing around 100km seems about right , and you're right about not giving it a bootfull for Boost to get up to 15psi , 300 tdi engine is brilliant engine IMO.
    May 2003
    On The Road
    wont finding the pressure drop across the cooler just be an arguement for a better cooler???
    Feb 2005
    good point......don't think the account will release the funds though
    The boost compensator is fitted to the injection pump for environmental reasons. It's function is to reduce the fuel when the boost pressure is low (not enough air to burn fuel completely).
    By connecting the line to the boost compensator from the manifold instead of the compressor outlet, you are fooling the compensator into thinking the boost pressure is lower.
    So it should reduce the fuel, causing power to drop. Less energy in the exhaust gasses will reduce the performance of the turbo and boost pressure should drop ...
