Results 1 to 10 of 21
Thread: HELP-gearbox problem-URGENT
    Aug 2008
    penwuf
    my dad has just taken the defender to canberra from sydney and he has lost 5th & reverse, it still goes into gear but doesnt drive, doesnt make any noises either,
    any ideas????
    its a 95 defender 300tdi with an r380 box
    Orange NSW
    I can't help with a solution to the problem but my "94 did the same thing last year after going bush. The next day it was fine and has been ever since. Hopefully yours will do the same.
    Steve.
    mike 90 RR Guest
    Quote Originally Posted by jacked130 View Post
    any ideas????
    Just to clarify
    It will drive in 1st to 4th gears .....
    BUT no drive when selecting 5th or Reverse??
    Douglas Park, NSW
    Seeing as 5th & reverse are on the same selector gate, I would say that might point to your problem.
    mike 90 RR Guest
    Found this link with exactly the same question
    Ashcroft Transmissions
    You are not going to like the answer tho
    Aug 2008
    penwuf
    Quote Originally Posted by mike 90 RR View Post
    Just to clarify
    correct
    Aug 2008
    penwuf
    Adelaide Hills - SA
    Try this thread before you slash your wrists
    R380 Problems
    He lost 4th and reverse, so it might be a different issue, but his was a cheap fix.
    Yass NSW
    Dosen't sound good. Does he know people in Canberra?
    If not I can recommend some places.
    Aug 2008
    penwuf
    i've organised a tow truck to go get him, he didnt want to spend the night in, just means i'm the lucky bugger that gets to fix it, the tow truck driver pretty much left just after i called him, $550 to pick it up from act and get it to penrith tonight, cant complain too much eh
