Results 1 to 10 of 16
Thread: Would'nt like to be out of warranty
    Just a few ECU's
    COMMUNICATION DATA BUSES
    DESCRIPTION AND OPERATION 86-4-3
    1
    ABS ECU
    2
    EAT ECU (ZF shown)
    3
    Air suspension ECU
    4
    Td6 ECM
    5
    Steering angle sensor
    6
    V8 ECM
    7
    Transfer box ECU
    8
    Instrument pack
    9
    LH xenon headlamp ECU
    10
    RH xenon headlamp ECU
    11
    Diagnostic socket
    12
    Low line ATC ECU
    13
    Air distribution motor
    14
    High line ATC ECU
    15
    Steering column lock ECU
    16
    Seat module
    17
    FBH
    18
    Face level air distribution motor
    19
    Windscreen air distribution motor
    20
    Footwell air distribution motor
    21
    Rear face level temperature blend motor
    22
    Ram air motor
    23
    Headlamp levelling ECU
    24
    Immobilisation ECU
    25
    TPM ECU
    26
    Rain sensor27 SRS DCU
    ENTERTAINMENT AND INFORMATION SYSTEMS
    DESCRIPTION AND OPERATION 86-8-9
    1
    Steering wheel switches
    2
    Video module
    3
    Multi Function Display (MFD)
    4
    Side window aerials
    5
    Alternative side screen aerial amplifier for
    parked heating
    6
    Television aerial amplifier
    7
    8
    Side screen television aerial and radio diversity
    tuning radio aerial
    9
    Side screen radio diversity tuning aerial
    amplifier
    10
    Rear screen aerial amplifier
    11
    Rear screen
    12
    Suppressor
    13
    Suppressor
    14
    DSP
    15
    Power amplifier
    16
    Radio module
    17
    CD autochanger
    18 Rotary coupler
    luxury is when your car has these..lol
    Two hydraulically dampened engine mounts are fitted between the engine support brackets and engine sub-frame to
    reduce the level of transmitted engine vibration and noise.
    The damping characteristics of the mounts are regulated by controlling the rate of hydraulic fluid transfer between two
    internal chambers.
    The system consists of two hydraulic mounts, with variable damping regulated by a vacuum, a control actuator,
    electric and vacuum lines. The vacuum, controlled by the electrical control actuator, is supplied via a distributor in the
    vacuum line between the vacuum pump and brake booster. The system is controlled by the EDC System.
    Wouldn't want that engine interferring with Bach on the stereo
    It really is true that modern devices are tremendously dependent on electronics. Luckily, they are mostly much more reliable than mechanical systems (to do the same thing).
     2005 Defender 110 
    You left out the fibre optic connections. I believe the D3 and Rangie use some fibre links as do other vehicles now days.
    Our BMW MINI had a data bus around the car and "nodes" on the network to operate various things. Ironically, that was one of the less troublesome aspects of the car
    mike 90 RR Guest
    Yes the 1990 RRC upwards uses fibre optics to illuminate the lights for the indicator & wiper storks on the steering column
    Luckily, it's not a big item
    The key to all of this is the reliability they are building in to these systems.
    If you want to scare yourself silly though check out this link:
    Microsoft - Windows Automotive
    Reminds me of the joke about the three engineers and the car not starting...
    Electrical Engineer: I think we should check the wiring from the battery to the starter...
    Mechanical Engineer: Maybe the we should remove the engine covers and look inside...
    Microsoft Engineer: Why don't we close all the windows turn it off and then open all the windows and see if it starts.
    Caboolture
    Is it just me or do electronic systems not like dust, water and vibration....................makes sense to put em in landrovers then
    Quote Originally Posted by Mick-Kelly View Post
    Its just you
    The reality is they should be sealed from dust and moisture and made to take the vibrations. e.g. The ballast on an HID spottie can last for years on a Landy, but lucky to get 6 months out of it on a CAT D11 because of the vibrations. But then 6 months of near continuous operation isn't bad either.
    That said some electronics are not built to meet the conditions they are used in.
    I see DirtyDawg has been doing some studying & learning how things work in his newish "posh toy"
    It is mind boggling to realise how many ECU's do their job.
    It is better than the P38, where everything was controlled by the BECM (or the big box under the drivers seat).
    At least this way u just replaced a smaller module instead of the whole heart...& is damn cheaper...
    Hope ya beast is treating you well.
