Thread: ACE is thumping
    Jun 2007
    Minchinbury NSW
    ACE is thumping
    I notice yesterday that the the ACE pump is thumping like a heart beat a single thump though I wonder what it is
    NSW SW Slopes
    I would be removing the belt and checking the pump's bearings quick smart, although it could be loose mountings.
    Jun 2007
    Minchinbury NSW
    I dont think its either the thump have to big of a gap between them to be a bearing its like thump 1234 thump 1234 thump
    mmmmmm
    99.87 MB
    What specifically makes it thump or does it thump all of the time?
    ie turning left to right and/or right to left? driving over little bumps, driving over big bumps etc?
    If its like a rattle, the rose joints you have can do this as they develop slop.
    Slunnie
    Jun 2007
    Minchinbury NSW
    No it’s not the rose joints I know them LOL
    its noticeable on Idle on a stand still when I lift the bonnet I can visually see the hoses that go to the ACE reservoir thump when I put my hand on the reservoir I can feel the thump its funny I cant here it whooosh noise that the ace does any more light flashes on and off here and there
    NSW SW Slopes
    Starting to sound like a problem with the pressure limiting valve or a blocked filter in the valve block beneath the driver's floor. Maybe its simple like a bad electrical connection but a hookup to an appropriate diagnostic device is probably needed for more info.
    Edit: Worth checking the electrical connections on that valve block.
    Jun 2007
    Minchinbury NSW
    its going to graham cooper next week to get the bonnet release cable fixed ill have checked then
