 Originally Posted by
Disco_owner
				I had the same issue on my RRC , when braking hard or approching set of lights slowing down to stop the car would stall and like you said it takes a good bootful to get the engine going again , I removed the front cover of my air filter unit and it seems to have solved this mystry , it almost seems like air pressure behind the airfilter box & the LPG converter is unbalanced and LPG converter cuts out Gas into intake manifold because of this????
However I still have to tap into the Intake airfeed and run a Hose back to the Convereter balanced feed and I'm told it will not stall again... I'm yet to experience this first hand.
