Results 1 to 10 of 19
Thread: Latest/Largest/Best Rover motor into '58 series one 86 inch.
    hotgemini Guest
    Hello,
    Let me start by apologising is what I'm about to ask is considered such common knowledge that it doesn't even bear discussion, I had a good read back through the archives of this forum, the tech forum, faqs and googled around but still haven't come across anything absolutely definitive.
    What I'd like to know, is what is the latest/largest/best evolution of the rover petrol 4 cylinder motor that will bolt up in place of the original 2.0 IOE motor?
    As best as I can tell the later 2.25 OHV motor is meant to bolt up without too much problem, but my googling tells me that this was replaced with a 2.5 litre motor in the SIII with a 5 main bearing crank and presumably other improvements. Does the later 2.5 petrol bolt up without excess hassle?
    For those who are concerned, the original 2.0 IOE will be suitably preserved, protected, palletised and packed away to retain the ability to return to stock down the track, but for whilst the SI is still being used then its probably better to chase power by going later/larger rather than by modifications to the stock engine.
    I suppose the other question is availability? Assuming it does go in, how common will I find 2.5s, preferably in SEQ. I apologise again, I'm not actually a land rover owner but rather have been tasked with research by a friend.
    -Adam.
    Melrose SA
    I figure that the most common Rover 4 would be the 2.25 Petrol I dont know of the complexeties in doing the conversion though.The 2.5 to my knowledge was not common in Australia but maybe you could import one from the UK.
    Why dont you just do up the old one and use it spend your $ on keeping it original and have a real classic??
    Rangier Rover Guest
    Not a 4 cyl but look right and go very well in Series1. A 3 ltr 6cyl out of Rover P6.
    The largest Rover engine that will easily go into your Series 1 is, as you say, the 2.5litre petrol or diesel. However, this development did not take place until the 110 in 1985 (five bearings came in about 1983 in the last of the Series 3 but still 2.25). And the 2.5 litre engine was never sold in Australia - the 110 only came here with the V8 or Isuzu, neither of which easily go into the S1. (and even five bearing engines are very rare).
    So from a practical point of view, the largest engine that will easily fit in the (88") Series 1 is the 2.25, petrol or diesel. Note that the bell housing on these is different from the 2.0, but bell housings are readily available from 2a or 3 vehicles (or complete gearboxes just bolt in). These engines should be fairly easy to find from rusted out S3s (the later engines are slightly improved, but more importantly, have had less use) and you may find new or reconditioned engines with a bit of looking round. All parts are readily available, and you could even overhaul a worn one.
    With a little more trouble, the 200Tdi or even 300 Tdi can be made to fit, but will require significant body and chassis modifications. Once you start on these there are other engines that can be made to fit, but these get beyond "bolt up".
    South Australia - Port Pirie
    Hi there
    I honestly believe you should stick with the 2lt engine..........with all the headaches involved with conversions etc........
    Rebuild the 2lt engine - as its already been said save your $$$$'s and maintain it as a CLASSIC. The series ones are becoming quite an collectable & desirable item
    Well thats my two bobs worth
    Wayne
    Melb. Vic.
    I'd be interested in the 2.0Litre if you do pull it out.
    I actually agree with Wayne - the 2.0 engine, when in good condition, provides adequate power for the 88 (albeit perhaps not for the 109!), and they really are a very nice engine to live with, smooth, quiet and flexible. If you wanted a high performance four wheel drive, you would not start with a Series 1!
    hotgemini Guest
    Not interested in all the other comments, but this was exactly the information I was after. Not interested in body mods, anything done to the S1 has to be reversible, hence the reason behind the wording of the query in the first place.
    For all those people whinging about the move away from stock... The more time that the engine spends *out* of the car, safely soaked in lanolin and shrink-wrapped, the MORE original the car will be down the track when it is re-fitted.
    This car sees ongoing regular day-to-day use, nothing would be sadder than to consign it to a glass-case, imho when that happens to classic cars its a travesty and a tragedy.
    The current 2.0 is in quite reasonable condition, but in my opinion it would be a shame to modify the original motor, when instead a 'non-classic' later motor (seemingingly a 2.25 being the choice) could be rebuilt as a nicer engine while the car remains in active use and retain the option of a straight-forward return to factory running gear down the track.
    So, next question, what are the practical considerations between just swapping bellhousings and retaining the S1 box/transfer, as opposed to putting the complete 2.25 engine and box in as a unit? Will tailshafts etc bolt up, if not, what is the logical solution? (eg. is there some combination of factory parts to make it work).
    -Adam
    Quote Originally Posted by hotgemini View Post
    -Adam
    The 2.25 engine, apart from the bell housing question is a straight bolt in job, I believe. There will be minor wiring and plumbing issues of course. Since the gearbox and transfer case remain in the same place, there is no issue with prop shafts. Series 1 88/109 transfer case and gearbox are, apart from detail changes, identical to Series 2/2a ones and the transfer case remains the same for the Series 3. (Be aware of the change during 2/2a production from BSF to UNF threads in a number of places, so nuts may not always fit when mixing and matching - just use the right ones and don't wreck any threads!)
    You need a 2/2a rather than 3 bell housing, as these retained the same clutch mechanism, with a cross shaft, where the 3 has a completely new fork setup. Handbrake mechanism went through a few changes, but bit are a bolt on swap.
    I would be inclined to look for a complete 2/2a engine/gearbox/transfer unit, as it avoids having to swap the bell housing. You will also need (which you may not have thought of) the elbow above the carburettor and the hose to the air cleaner (I think the aircleaner is the same, but the outlet may be a different size - check it).
    I hope this helps,
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by Rangier Rover View Post
    Not without doing the same cutting of body panels and chassis as you do for a Holden straight six engine conversion it won't. More than that it would be a waste of time preserving the 2 litre to put back in.
    It would however bolt up to the Series 1 55-58 bellhousing, provided that you used a Land Rover 2.6 flywheel housing and swap the 10" clutch system for something usable in the S1.
    The 2.5 litre will be hard to acquire in Australia. The 5 bearing crank 2.3 litre will fit provided you change the gearbox bellhousing for the one out of a series 2 2 1/4. There can be issues on layshaft front bearing if you use some 2a bellhousings.
    Diana
