Results 1 to 10 of 19
Thread: how hot?
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    how hot?
    How hot should the intake pipe between the turbo and the inlet manifold get when engine is working at 2000 rpm ?
    cook your dinner hot ?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    it picks up a heap of latent heat from the turbo and the exhuast manifold...
    I wouldnt call it cook your dinner hot... reheat maybe.
    if you sit a ham and cheese crisonte just behind it on top of the rocker cover it does an excelent job of just melting it enough.
    Kingston, Tassie, OZ.
    Dave, (Inc)
    Without an intercooler, quite hot indeed. It isn't out of the question to see 55 to 65deg(A cup of coffee temp) from the compressor outlet. Obviously depending on boost presssure/ fuelling etc but you get the idea. This is why anything over 10psi really should be intercooled to enhance efficiency.
    You've probably heard this before, but after a hard run up a long hill, I can hold my hand ,just, on the upstream side of the I/C pipe, but into the manifold it is cool to the touch. Fantastic job the I/C does. I have a study background many years ago in thermodynamics, and without trying to quantify it without actual measured figures that I just don't have, the temperature differential across my intercooler is definately showing a marked increase in efficiency=less fuel= more power.
    JC
    I suspect your terminology may be mixed up a little - latent heat is heat associated with a change in state (e.g. solid to/from liquid, or liquid to/from vapour), and there is no change in temperature.
    When something is heated/cooled and there is a change in temperature, it is called sensible heat.
    Quote Originally Posted by Bush65 View Post
    John, Very sensible reply.
    JC
    WA
    Quote Originally Posted by incisor View Post
    How hot yours gets will depend on ambient temp, how much boost you are running, and how quickly it can be dissipated.
    Cook your dinner hot is possible.
    your correct but your wrong.....
    the word I ment was conducted.....
    how i got that to latent..... urmmm errr.... not enough coffee?
    and yes I know the heat it picks up from the exhuast manifold would be radiated heat not conducted but see the line about not enough coffee....
    (good catch)
    As Justin said, there are thermodynamic principles involved. But there is inescapable heating from compressor efficiency.
    The compressor map for the turbo has a set of curves that plot efficiency for output flow vs pressure. The efficiency plays a considerable part in the amount of heat generated.
    If the compressor is operating in an inefficient region it's wheel is spinning (think of wheel spin or torque convertor slip) much faster relative to the air flow created. A large portion of the power from the turbine is converted to heat energy instead of gas flow.
    Quite often, when the boost pressure is adjusted up, the compressor becomes less efficient, the heat and boost increase for little improvement in airflow or power (but it improves the bragging factor). A better matched compressor (or modifying the compressor) can allow more power with lower boost pressure, in these cases.
    yep.
    the compressor heats the air as it compresses it, so it will be too hot to touch the pipe, and the radiant heat in the engine bay also heats everything. this heating due to compressing is the reason we have intercoolers, to get more air into the engine, in turn , the more air in , the more fuel we can got in to get more power out.
    sorry, didn't mean to give lessons.
    it's a land rover, everything under the bonnet is too hot!!!!!!!
    Safe Travels
    harry
    WA
    Just so I understand...
    this heating you mention due to inefficiency is unrelated to adiabatic heating?
