Navman / Tom Tom's etc not a straight GPS per se - they are "Street Navigators" designed to direct townies to their barbecues and movies. So no, they will not normally give you a "snail trail".
Most of the simple trekking type GPS units without mapping functions ( eg ETrex) will give you a snail trail function if that's all you want.
The best way to go ( IMHO) is a PDA type unit, with inbuilt GPS, running OziExplorer CE. You can then buy/share the hundreds of available maps out there, or even scan in your own paper ones if you want to. A lot of these will also have a "Street Navigator" type function (eg Tom Tom) as well. If you can't be bothered setting it all up yourself, look at the Hema Navigator, which is bascially the same thing but all set up for you.
It's been useful a few times.
