Results 1 to 10 of 30
Thread: some engine questions....
    ok so Im bored..... I'll give answers in a couple of weeks....
    think you know engines and motors....
    What types of engines/motors provide better preformance at higher altitudes without having to be retuned?
    What types of motors/engines provide maximum torque at 0 Rpms.
    Whats the maximum number of strokes that a reciprocating engine has used and remained effective?
    does a reciprocating engine have to have a crank shaft?
    can a diesel engine have a carby, more importantly can it have it as the only source of fuel that gets to the combustion chamber?
    do you have to have valves in a reciprocating diesel engine?
    what fueled the first reciprocating engines?
    running diesel can you put 2 pistons into a single cylinder? if you can how could you make it work?
    have fun....
    99.87 MB
    I'll have a go.
    What types of engines/motors provide better preformance at higher altitudes without having to be retuned? Oops, the ones the use on shuttles etc which carry all fuel.
    What types of motors/engines provide maximum torque at 0 Rpms. Electric
    Whats the maximum number of strokes that a reciprocating engine has used and remained effective? 6
    does a reciprocating engine have to have a crank shaft? no
    can a diesel engine have a carby, more importantly can it have it as the only source of fuel that gets to the combustion chamber? yes, yes
    do you have to have valves in a reciprocating diesel engine? no
    what fueled the first reciprocating engines? parrafin
    running diesel can you put 2 pistons into a single cylinder? if you can how could you make it work? yes, one was a guide on extra long stroke motors.
    have fun....
    Slunnie
    you have 4 right, 1 wrong, 2 half right and 1 I'll give you credit for but its not the answer I was looking for.
    99.87 MB
    Hmmm, actually maybe it needs more thought. The reciprocating one was probably really the waterwheel.
    Slunnie
    Goolwa SA - but top ender forever
    apart from what Slunnie wrote, I think the commer knocker motor had two pistons in one cylinder which would answer the last question as a yes
    Blythe
    Not really showing my age just remember a conversation about engines with my dad years ago.
    2 pistons in a single cylinder -yep - commer knocker -con rods out to rockers back into crankshaft
    recip engine - crankshaft - rotary, still has a bit in the middle, to hold the rods, but the cyls and crankcase are attached to the prop.
    Safe Travels
    harry
    harry, nice try on the rotary engine but no, the bit in the middle is still occasionally refered to as a crank...
    when a rotary is in a stationary role (as in the sherman tank) the casing is held and the crank turns....
    good effort tho.
    nope the water wheel technically falls under the turbine class of engine.
    Jul 2007
    What types of engines/motors provide better preformance at higher altitudes without having to be retuned? RAM jet
    What types of motors/engines provide maximum torque at 0 Rpms. DC electric
    Whats the maximum number of strokes that a reciprocating engine has used and remained effective? fourdoes a reciprocating engine have to have a crank shaft? Yes if you want to convert reciprocating motion into circular motion otherwise no
    can a diesel engine have a carby, yes model engine planes use them more importantly can it have it as the only source of fuel that gets to the combustion chamber? yes
    do you have to have valves in a reciprocating diesel engine? No it could be a two stroke using reeds
    what fueled the first reciprocating engines? What Slunnie said
    running diesel can you put 2 pistons into a single cylinder? if you can how could you make it work? Two stroke diesel with the piston crowns pushing towards each other, cranks at either end with a connection between them. It looks like a boxer configuration sort of
    have fun....
    clean32 is offline AULRO Holiday Reward Points Winner!
    SA, Newton
    Coxaxel jet, rocket, any forced induction
    Electric ,Steam
    6,
    NO, wash plate etc
    Yes Yes
    No, 2 stroke, reed or rotary Valve, sleve valve,
    Gun powder, comresed air, steam
    Yes 2 pistions 2 barals split Crod, the first pistion being used for comprestion only ( tubo, supercharger ) or with both pistions compressing and burning but with difrent crank timing ( comon combustion chamber) OR oposed pistions, 1 barral 2 cranks ( i think a german WW2 airplane had a motor like this??
    have fun....
    did i win? but not the spelling LOL
