If there is any corrosion at all in the cylinders, then it is best to re-sleeve them, especially if you want to keep it original. Do a complete system overhaul while you are at it, i.e. check the drums for wear and change the pipes if they are rusty. New brake parts, except for the BSF wheel cylinders and 80" master cylinder are freely available.
Welcome to the forum,
Cheers Charlie
I have now got a lathe for this reason as have so many old trucks, rovers etc.
