Results 1 to 9 of 9
Thread: engine transplant
    Aug 2008
    Thumbs up engine transplant
    Last Saturday this month I am swapping my L/R 2.6 6cyl for a 3.3l/202 6cyl after many months of procrastinating!
    In any case, the existing L/R 2.6l 6cyl is in very good condition with a near new carby, near new dizzy and coil, transistor assisted ignition and will be up for grabs, price to be advised, however I am open to offers.
    It starts everytime and I have kept the oil change and tune right up.
    Oh, it also has a recon head with a new set of valves.
    I have an engine crane to load it into a trailer.
    I live in East Doncaster Vic.
    PM me if you're interested.
    The main reason I am swapping it is that I do a lot of long distance cruising and just found the 2.6l wanting for highway cruising. I do very little offroad with my SIII so don't need a lot of torque and want to sit on 100km/h even with a head wind!!
    Sorry to say it but the holden engine is not going to help your cruising - a bad engine choice. The rev characteristics are all wrong for the landie gearing - landie engines have a flatter torque curve than holden engines so when cruising the holden engine will have to rev higher than its 'sweet' spot - basically it will be reving at a level where torque is tailing off.
    You might want to have a rethink -even a good 2.25 petrol landie engine works better than a good holden engine with standard landie gearing.
    Free Again Thanks Dan
    ^^^^^^^X2^^^^^^^^
    Unless you change the gearing the holden engine will not last very long at 100 km/h before it self distructs ( a leg out of bed )
    Higher range transfer case from 4x4 in blackburn would be my first port of call before changing the engines
    Aug 2008
    thanks for the input guys.
    I do have a Fairey Overdrive and a friend of mine has exactly the same setup and has been running it for about 4 years with no adverse problems, so that is what I based my conversion on.
    However, should I do have problems, a higher range transfer would be my first option.
    Northern Victoria
    Hi Romulus.
    Have sent you a PM.
    AJ
    May 2008
    Greenbank Qld
    engine swap
    Shame your so far away I'd swap my 202 with ya.
    i do 120klm round trip to work each day, 90 klm of this on the hwy, the 202 screeaaaams at 100kph (no overdrive) i stick to about 80-90kph.
    Also get about 270klm from the 10gal tank.
    Northern Victoria
    Sorry Folks!
    Sorry folks!
    I already got that one this morning--Im just waiting for Romulus to give me a call when its ready to pick up
    A.J.
    Aug 2008
    Thanks for all the extra info people.
    Do any of you have had experience with a 202 and a Fairey Overdrive?, would appreciate some input on this, thank you.
    I am assuming that the 5th gear would/should make a fair difference in engine RPM.
    Like I said though, my SIII is purely a weekender, fitted out for camping and fly fishing, nothing more, but should the RPM be too excessive, I will get higher ratio transfer gearing.
    Aug 2008
    Quote Originally Posted by SIImad View Post
    Sorry folks!
    A.J.
    Yes, sorry, meant to post this here yesterday.
    The 2.6 is 'sold'.
