Results 1 to 10 of 15
Thread: 35s on a d1
    Nov 2008
    35s on a d1
    hey guys,
    Ive just bought a v8 manual discovery, as im neew to LR i need to know what lift is required to fit 35x10.5r16 simex. i have already ordered ashcroft axels and cvs,
    thanks travis
    mcrover Guest
    So your after something like this.
    That has (in that guise) I think as it's not my car but at the time was 3" suspention, 1" or 2" body (not sure) off set rims with LRA flares.
    worked pretty well
    Nov 2008
    pretty much what im after anyone else shed some light on what is needed for the lift?
    99.87 MB
    Keeping in mind that I'm more into D2's, I thought that 2" suspension + 2" body + cut guards and flares + offset rims was fairly standard when fitting 35's to a Disco1 or RRC. Then Barwork lift to suit.
    Slunnie
    ChCh New Zealand
    Quote Originally Posted by Travis View Post
    hey all,
    I have already ordered front and rear ashcroft axels and cvs and have a rear jack mac locker. Thanks
    I've just fitted Ashcroft Axles and Cv's. Just be aware if you have an early model Disco you will need to change your stub axles and have them machined. I've just had to find all this out the hard way.
    I'm not sure about 95 onward models though.
    Nov 2008
    yeah its a 96 model, ill have to check with the guy i ordered them through....
    Rye or cranbourne
    pretty much what slunnie has written will fit 35's,jamie of allranges disco has 80 series shocks and 2 inch body lift and lra xl flares and has excelent wheel traval,then just change things when you break things
    Yinnar South, Vic
    Diffs, axles and ratio's. ARE the most important part to this combo
    Warrandyte, vic
    I have on mine 3 inch spring lift. 40 mm body lift, LRA flares and offset rims. Looks very similiar to Jamie's even the bend in the aerial, or should I say his looks similiar to mine - mine was done first
    Quote Originally Posted by rovercare View Post
    This is the bit you need to do to get it all to work properly.
    Redbank Plains
    Hey Travis,
    I have 3-4 inch spring lift, 2inch body lift, flares, 4.11s, au CVs, Maxi's and reduction gears. I have offet rims and also had to extend the rear bump stops drastically to stop the tyres hitting hard on the back corners of the inner guard. Let me know if you need any other details.
