Results 1 to 8 of 8
Thread: A couple from work
    May 2002
    Heathcote (in "The Shire")
    A couple from work
    Some days are better than others - and you can get out of the office.
    Martyn
    May 2008
    QLD - Sunshine Coast
    Good shots......
    Jun 2003
    Launceston, Tasmania
    that first one is simply stunning, let alone unusual!
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    Quote Originally Posted by Phoenix View Post
    Love the flame against the green beside it.
    mcrover Guest
    I'd be thinking that it's going to be a busy one for you guys this year.
    Great shot that first one
    Normanhurst, NSW
    Agreed.
    Is there a story behind that very unusual shot?
    Roger
    May 2002
    Quote Originally Posted by Xtreme View Post
    Agreed.
    Roger
    Not really Roger, one of the things we do before lighting up a larger area is a test burn, this confirms the rate of spread, and that it will actually burn within our parameters.
    The tree just happened to be a little behind the test area and after a while due to the preheating, the fire ran up the bark.
    It demonstrates why, if you are in a bushfire prone area that smooth barks are preferred to rough barks.
    From a slightly wider angle
    Martyn
    Normanhurst, NSW
    OK - Thanks Martyn.
    The wider view and the 'test burn' explains it.
    Just that everything looked so green in the first 'graph that it didn't enter my thoughts that you would be testing for a HRB.
    Roger
