Thread: blinkers
    Nov 2007
    Bundaberg,Qld
    blinkers
    Hi trying get the blinkers to flash at the moment they just stay on.Is there flasher relay somewhere any help would be appreciated.
    Cheers Glenn.
    the flasher can is behind the dash
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    The flasher should be on the bulkhead, on the engine side, middle, top. But many 2/2as did not originally have flashers, and it may have a non-standard installation.
    WA
    What JD said. Sometimes if you give it a tap it will start working again (at least for a while).
    Caboolture.Qld
    Hi Glenn, On my two IIA's it is mounted on the firewall in the engine bay next to the fuse box
