View Poll Results: Is it buggered?
Voters
58. You may not vote on this poll
  • Yes, better find a quick 2k for a set of Coopers
    20 34.48%
  • No, chance, she'll be right mate
    38 65.52%
Results 1 to 10 of 37
Thread: Is this tyre buggered?
    In my ongoing quest to provide Goodyear shareholders with increasing revenue, it seems to my untrained eye I might have buggered another tyre.
    It's 3 to 4mm deep at the ugly looking bit.
    Sage advice and witty comments are welcome.
    Free Again Thanks Dan
    If its holding air she will be right mate
    99.87 MB
    If it's not deeper than the tread block then there is probably no need to worry.
    Slunnie
    Legally speaking, no, it won't pass; practically, should be good for a few more thousand kilometres.
    Last edited by JDNSW; 19th November 2008 at 08:10 PM. Reason: improve wording & punctuation
    I'd rather drive on that tyre than a set of Coopers...
    Feb 2005
    i sliced a bfg at and got another 12 months out of it before water got into the steel belts and the tyre failed
    Rangier Rover Guest
    I'm always cutting tyres here. I just stick a sleeve in side the case and run it on the rear if posible. If bad use as a spare.
    Tony
    I've had a tyre fail once.
    Really don't want to do that again.
    Simon
    Nuffin a bita no more gaps wouldn't fix ....
    I''ve seen worse,
    I''d put it on the rear though
