Results 1 to 10 of 11
Thread: series one steering wheel removal
    Caboolture
    Okay brains trust, how do i get the old busted up wheel off on the 80 inch. Ive undone the bolt and soaked the shaft in WD40, even hit it with the big hammer. No joy so far. Any thoughts.
    You have to take the bolt out - it is in a groove in the shaft. If you have already done this, you need to get or make a suitable puller and gentle warming of the diecast hub will expand it more than the shaft, and should work. If the wheel you are removing is scrap, then more than gentle warming may be indicated.
    Rangier Rover Guest
    If it still won't play the game after ^^^^ Drill a lot of holes and split it with a chisel. Take care of the shaft spline.
    Tony
    Steering wheel
    I found the angle grinder with a 1 mm blade
    several cuts
    nice pointy tool, big hammer
    destroyed the steering boss
    have fun
    Ian
    Rangier Rover Guest
    Quote Originally Posted by back_in View Post
    several cuts
    have fun
    Ian
    But the drill is cordless and very gentle
    marcoseries1 Guest
    heat!
    By far the easiest way.....Heat the aluminium boss with a blowtorch, expansion rate of dissimilar metals will break the bond, without damaging the splines.......:-) Works every time
    Marco
    Caboolture
    Thanks for the replies guys, i will let you know how i go. Must sleep now..........................................
    East-South-East Girt-By-Sea
    1.20 MB
    marco's idea is good, however with a very stubborn wheel I have resorted to the use of several CV/tie rod end tools, of sufficient size to pass over the shaft.
    The first one inserted flush with the shoulder on the back of the wheel and the second one inserted from the other side. You then tap the second one againse the first and the wedging of the two tapers works against the shoulder on the steering column and the steering wheel. The same as a puller would have done.
    You may need to have the tools for truck sized tie rods, but our workshop already had them.
    Diana
    Sep 2006
    Warragul
    steering wheels
    It's a common problem, not isolated to Land Rovers. Heating will help , but that aluminium boss has a relatively low melting point .. maybe a LPG torch is the way . A oxy flame will be too hot to use on a good steering wheel.
    With steering wheel pullers , they can splay out the end of the shaft .. damaging it. I damaged a Dodge doing this and I had to use a thread file to re-profile the thread on the shaft in order to get the nut back on .
    One I had on a jeep, we had to use a shop press to get the wheel off .. I dismantled the steering box in situ and I got the shaft out through the firewall , with the wheel still attached .. A friend took it to his work and he used a big press to get the wheel off .. he said it took about 5 tons or something like that !
    Mike
    Sep 2006
    Warragul
    steering wheel
