Results 1 to 8 of 8
Thread: Series One "Welder"
    South Australia - Port Pirie
    Series One "Welder"
    Hi there
    This unique piece of Land Rover history (Land Rover Welder) which is owned by a friend in Adelaide SA.......enjoy the pictures.
    All the best
    Wayne
    Rangier Rover Guest
    Wow... One in real flesh. I want it.
    Looks like it will buff up OK as well.
    Tony
    Boonah, QLD
    what runs the welder - that extra generator looking thing hanginf off the right side of the engine?
    Sounds like a good idea, I want one too
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by Newbs-IIA View Post
    The welder is run by a set of "V" belts from the gearbox PTO. The thing you describe as a generator is actually the governor which regulates a constant speed irrespective of the load applied by the welder.
    Unfortunately the vehicle seems to be missing the Oxy-Acetylene bottle brackets and equipment.
    Diana
    And the question of course is whether it is a factory welder or a local conversion?
    1.20 MB
    The tool box looks to be the original factory type and if it's the vehicle that I think it is, it is a genuine factory welder.
    80" welders are easy to check, as they have their own chassis number sequence.
    When there were less than a couple of dozen vehicles produced in any year, they deleted the sequence for the 86" and later models.
    Diana
    Hi there
    Its an original land rover factory welder.......
    All the best
    Wayne
    PS a huge job to restore......
    Picture three is the actual welder. The round bit down the bottom is the generator bit. This welder has a more complicated governor. When an arc is struck, the load goes from zero to full in an instant. The mechanical governor would have a time delay to increase the throttle. A bellows is employed, which is controlled by the welder. When the arc is struck, a vacuum is applied from the welder, which sucks on the bellows, to pull the throttle open. The degree to which this occurs is regulated by a mercury tilt switch, which sits on the connectong rod between the bellows and the carburettor. After a short period of time, the mechanical regulator would have taken over again, by opening up the throttle.
    I too know this welder. It is a genuine factory welder. On Saturday evening, I was crawling underneath it acquainting myself with how the oil cooler plumbs in. Quite different to the later 2.25L versions.
    Aaron.
